Question about Sport & Outdoor - Others
I have a shakespear sea wonder 2091 fishing reel the bail will not close
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
  • 7 Answers
SOURCE: I have a shakespeare sigma fishing reel that
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
Posted on May 21, 2009
SOURCE: shakespeare 2660 coarse fishing reel,cant remove spool cover
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
Posted on Jul 12, 2009
  • 10 Answers
SOURCE: Shakespeare fishing reel schematics
try online at www.reelschematics.com they should be able to give you help.regards barry.
Posted on Sep 29, 2009
  • 17 Answers
SOURCE: I have a shakespear alpha fishing reel which
The switch is the on/off anti reverse switch. It is the switch (probably the only one) on the reel at the base. When the reel is in the upright position, look at the bottom/rear area. That little level controls the reverse. Good fishing...
Posted on Nov 16, 2009
Testimonial: "Hi Thanks "
Need Shakespeare 2210 repair manual
Quite likely one of the best fishing reel sites I have seen for servicing reels - your manual is quite likely in this list:
http://schematics.mikesreelrepair.com/thumbnails.php?album=24
Nov 01, 2017 | Sport & Outdoor - Others
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Need to know were the long spring on my sons spider man rod and reel goes
The long spring (only one in the reel) goes under the bail arm plate. To get it back in, remove the plastic cover plate on the side that pickes up the line (has a line roller on that side). The spring will fit over a small metal or plastic post and rest in a cavity at the bottom.
Screw the cover back on and you're good to go!
Best of luck
Mike
Sep 26, 2009 | Shakespeare Surf Fishing Rod and Reel...
Ladyfish fishing pole by shakespeare
try switching sides of the handle by holding the bell and reeling then screw it in on the other side of the real by just reeling in. If that doesn't work then take all the line out and reel in some new line the opposite way.
Aug 06, 2009 | Shakespeare Surf Fishing Rod and Reel...
What do you do with the line before threading it through the eyes
Take the line off the spool in such a way that the line will be caught by the bail after you cast the line. The easiest way to get it right is to raise the bail like you are going to cast the line, thread the eyes, then trip the bail with the handle, as though you were reeling 'em in.
Happy fishing. I'm jealous.
Best regards, --W/D--
Jul 20, 2009 | Shakespeare Surf Fishing Rod and Reel...
Jul 01, 2009 | Sport & Outdoor - Others
Shakespeare 2660 coarse fishing reel,cant remove spool cover
Mar 17, 2009 | Shakespeare Agility Spinning Reel 6825
Sport & Outdoor - Others Logo
42 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
