Question about Juki Sewing Machines
Juki 600 bobbin not catching - Juki Sewing Machines
4 Suggested Answers
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
SOURCE: When using the automatic thread trimmer on my juki
YOU MAY SEE THREAD HANDLER HAVE SOME PROBLEM. THERE MAY BE SOME THREAD TON IN IT
Posted on Feb 27, 2011
SOURCE: I have a Juki DU
Be sure you have the proper needle - it is longer than standard needles, plus be sure that you put the needle in from left to right - not...front to back.
Posted on Apr 26, 2011
Hi I just purchased a used Juki DDL-555. 1) It will not catch the bobbin thread. 2) it will not sew forward and feed the fabric along (it sews in reverse just fine). Can someone please help?
the material movement is set by the forward/ reverse knob or lever
not picking up the thread can be needle thread tension too loose
it can be needle hook timing
Apr 20, 2017 | Juki Sewing Machines
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
Juki.co.jp
Make sure you are threaded correctly. Also be sure that your bobbin is sitting in the casing correctly. If the timing is right and the hook is catching, the thread may not be pulling through correctly. Clean your machine as well. Make sure your tension spring is clean and doesn't need to be tuned up.
May 01, 2014 | Juki Sewing Machines
I have a Juki 1541s the needle will not catch the bobbin
At this point I would take the manual and do a proper 'take apart and clean' on it. I have had this happen as well, and most often, even tho I don't see the creator of the issue, cleaning/oiling makes it fine. And make sure you use a good sharp needle. Nothing worse to make a machine not work correctly in a bad needle. Tighten up the needle in the machine as well. There could be fuzz on the hook within the machine.
Mar 05, 2014 | Juki Sewing Machines
Oily bobbin
Sounds like you've over oiled your machine. Take the bobbin out, strip the thread from it. wipe it down well... and re-wind the bobbin with new thread.
Next time you oil after your day of sewing. Place a piece of absorbent scrap fabric under the presser foot to catch excess drips.
Sep 27, 2013 | Juki DDL-8700
I have an 8700 juki industrial machine and as I'm sewing the thread will not catch on the bottom bobbin. I'm frustrated.. It was fine the last time I've used it.
machines do not just go out of time. Is the top threaded correctly. did u miss threading thru the take up arm or take up spring change needle too.
Nov 26, 2012 | Juki Sewing Machines
I have a Juki DDL 227. Top thread keeps breaking instantly
Well, you've not checked "Everything" but you have checked the common things.
Do you have any idea of where it is actually breaking? Re-thread your machine and see if you can determine exactly where the break occurs.
Sometimes a damaged needle throat plate will break threads... as will a burr on the hook in the bobbin area. Also if there is a burr or rough spot on the thread spool it will sometimes catch and cause breakage.
Good luck
Jul 23, 2012 | Juki Sewing Machines
When the needle goes down into the bobin area below, it catches on the "round about", so the whole point is that it misses the thread, and doesn't catch it, what can i do to fix this??
It sounds like your problem is as simple as either a bent needle or a bobbin casing that is inserted improperly. First, change your needle being mindful of the type of fabric (and thread) you are using (e.g. Size 11 ballpoint for a light knit or a size 18 jeans needle for denim). Make sure that the bobbin casing is set in correctly, and that the bobbin goes in the correct way. (i.e. Counter-clockwise for a drop-in style bobbin). This should solve your issue. Happy sewing!
Jun 22, 2011 | Juki HZL35Z Mechanical Sewing Machine
I have a Juki DU 141NH industrial sewing machine. I just had it serviced. I had to put a new bobbin in and now the needle is not catching my bobbin thread. Please help!
Oct 07, 2010 | Juki DDL-8300
Sewing Machines Logo
19 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
