Question about chicago electric power tools 10" Compound Miter Saw with Laser Guide System
Cant find locking pin on the 10 in miter saw - chicago electric power tools 10" Compound Miter Saw with Laser Guide System
Product just arrived, saw is stuck in cutting position
There is usually a safety or transit lock or pin which is engaged to lock the saw down for safety and for a more convenient way or transporting it.
The ones on my saws are a simple ball-headed pin sited close to the hinge of the saw which can be easily withdrawn once enough downward pressure has been applied to the saw to overcome the return spring pressure.
Mar 15, 2015 | Dewalt DW713 NA 10" Compound Miter Saw
Cant pull out locking pin on miter saw
There is a heavy spring which is trying to hold up the saw that is working against you. Press down on the handle of the saw so that it moves down a little, now you should be able to pull out the pin.
Good luck.
Jun 13, 2012 | Hitachi C10FCE2 10" Compound Miter Saw
Is there a locking pin on the right side of the saw that lets the saw spring up?
it should spring up by itself,it may be broke hence the name BUFFALO. there should be one to keep it down. it is next to the hinge.need to hold it down OR UP ? just use a black bundgie cord. jay
May 25, 2011 | Buffalo Tools 10" Sliding Compound Miter...
How do i unlock the safety position on my Ryobi miter saw?
There should be a metal pin on the back left side(tool facing you) near the pivot point. Just pull this in or out to lock/unlock the safety position.
Mar 02, 2011 | Ryobi ZRTS1342L Factory-Reconditioned 14...
How do you release the saw blade from the closed position on a Hitachi C10FCH 10" Compound Saw?
Hello, W/D here.
At the back of the saw, where it hinges, is a pin that locks the pivot joint. Push down on the saw handle while pulling the pin, then allow the saw to rise to the ready position. Reverse the order to store the saw.
Best regards, --W/D--
Feb 23, 2011 | Hitachi 10" Compound Miter Saw (with Laser...
I borrowed a chop saw and it is in lock position, how do i release it
on the back of the saw where the arm goes up and down there is a pin that pushes in it will only stick out about a 1/2 inch.
Feb 23, 2010 | Hitachi C10FSB 10" Sliding Dual Compound...
How do you open miter saw
Most of them have a horizontal pin about a 1/4" in diameter in the back of the saw where it hinges. Just need to pull out the pin.
Nov 22, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
How do i unlock the saw haed
Hello Derrick,
Take a look at the right rear pivot point of the Miter Saw and you should see a shiney metal pin that you can pull out (it's captive so it'll only pull out 3/4" - 1") that releases the saw head lock mechanism. This is designed so it is easier to carry the miter saw around.
If you want to see exactly what I'm talking about, I've attached a link to the Ryobi web site that takes you to the manual for this saw, don't the model number throw you off, as they add some digits for reconditioned units, etc. Take a look at page 11, figure #2 and you'll see the head lock pin I'm referring you to. It's just about the Miter angle scale.
http://www.ryobitools.com/product_manual/file_url/378/TS1342L_329_eng.pdf
Please print out and save an electronci copy of this manual for future reference and use. I have a file folder on my home computer that I've titled "MY TOOLS" and I keep electronic copies for all the manuals for the tools and gear I have. That way, I'll always have one, even if I lose or damage the paper copy.
Hope you find this Very Helpful and best regards!
Nov 17, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Sep 20, 2009 | Makita 10" Miter Saw LS1030N
Can't raise the saw assembly in ordr to cut wood
Search the rear of the saw for a locking latch or pin...
Feb 20, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
chicago electric power tools 10" Compound Miter Saw with Laser Guide System Logo
Top chicago electric power tools Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a chicago electric power tools Saw Expert? Answer questions, earn points and help others
