Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Whirlpool dishwasher The dishwasher works off and on. Every few days it stops going on altogether...only the cancel button goes on and the the dishwasher's timer says 2 minutes. Sometimes the air dry button works,but none of the other buttons work. The problem has been when the repair person comes out, it all of a sudden starts to work and so he can't diagnose the problem. I spoke with someone who said it sounds like with the touch pad or computer control board is bad. You don't seem to list my exact model no. which is GU1500XTLB2, serial no. FP3304L5
  • bmggpagan Nov 06, 2008
THE TECH WHO CAME TO FIX MY DISHWASHER FROM Y=THIS EXACT PROBLEM TOLD ME THAT IT IS CAUSED BY THE WATER THAT TAKES TOO MUCH TIME TO GET WARM, SO YOU HAVE TO MAKE SURE THE WATER IS NOT GOING TO BE COLD BEFORE YOU TURN THE DISHWASHER ON. AS TO FIXING IT, THERE IS A SEQUENCE THAT YOU MUST DO ON THE KEYPAD THAT WILL RESET IT, UNFORTUNATELY I LOST IT....
Posted on Oct 22, 2007
  • 447 Answers
Yes i have had this problem most likely a console/touchpad assy
Posted on Sep 27, 2007
Turn dishwasher on . the water loads in and then goes into wash cycle, it does it's wash cycle then drains and will not load clean water for rinse cycle it just hums a and then quits, then tries again and...
Tim Derbowka, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Tim Derbowka), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool GU2300XTS 24 in Builtin...
'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Oct 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Dishwasher does not complete cyele
Sounds like you might need a new Start button.
Mar 15, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher won't start
I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
Jan 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
hi there,
your problem is intermittent and before you start replacing parts, i would recommend that you do these checks:
unplug the dishwasher from the wall
check the connection between the touchpad, which is attached to the front panel & the control boad behind it.
also check the control board for any corrosions, kinks or burns
check the wiring harness connected to the board for the above as well
check the door latch to see if the door is closing correctly, as sometimes the switch inside the door latch does not make full contact for the door to shut.
replug the machine back and watch for the next couple of days. if the problem still persists, i would replace the keypad first.
Oct 01, 2008 | Dishwashers
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
KitchenAid Normal light stays on
check to see if its a draining problem,blockage under the sink etc ive not worked on this brand before.hope this helps.Ian
Mar 19, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
134 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
