Question about Weslo Cadence G 5.9 Treadmill
Treadmill sqeaky and skipping - Weslo Cadence G 5.9 Treadmill
Treadmill belt doesn't run smoothly
First of all lubricate the treadmill. If it didn't workout then try to tension the walking belt.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=b1MU7MvBETs
https://www.youtube.com/watch?v=JC72OIKdluY
Dec 27, 2015 | Bodyguard T240 Treadmill
ProForm Space saver treadmill was closed while inclined, belt skips and moves to side
see the video and proceed according. God bless youlube the rack and pinion of elevation motor, and adjust the small POT attached. see the diagram attached.
Apr 05, 2013 | Exercise & Fitness
The belt is skipping
hi,
You have to tension the belt of your treadmill. Here i have added a video which will help you to do the same. All the treadmills hve the same procedure.
ok
Aug 04, 2011 | Weslo Cadence 60 SE Treadmill
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
The belt is slipping or skipping
If the machine is a couple of years old and you've used it a lot, you probably need a new belt. You can order one at Treadmill Parts.
Oct 25, 2010 | Proform 665 E Treadmill
Belt skips
This typically means the belt is worn - or not tensioned properly.
Look in your owner's manual - and it will tell you how to properly tension the belt with the included spanner wrench.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2010 | Proform 540ls Treadmill Walking Belt
Treadmill wont work
your belt is probably loose. does it slip or skip when you step on it? Turn it over it has adjustments on the underside or somewhere close.
Nov 01, 2009 | Proform Sport 1000 Folding Treadmill...
Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Jan 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Weslo Cadence G 5.9 Treadmill Logo
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
