Question about Diamond Multimedia S3 Trio 64 86c764x 9550 fa2354 Stealth 64 DRAM T PCI 2MB VGA Graphics Accelerator Video Card - v 2.09 - Expandable to 4MB
Tablet volume stop working - Diamond Multimedia S3 Trio 64 86c764x 9550 fa2354 Stealth 64 DRAM T PCI 2MB VGA Graphics Accelerator Video Card - v 2.09 - Expandable to 4MB
Why can't I get sound on my tablet?.
There are a few ways to solve this problem.
Firstly, turn the device off.
2. Make sure your headphones are plugged ALL the way in (you should hear a click sound)
3. Press the on/off button and the volume up button at the SAME TIME
4. Once the screen is on let the on/off button go
5. DO NOT let the volume up button go
6. Wait until the tablet has finished loading all settings up.
7. Let volume up button go.
It should work now.
Jul 03, 2015 | Compaq Presario 700 470024-192 Notebook
I forgot my Acer tablet pin.What do I do
Power off the tablet.
Press and hold the Volume up button, which is located closest to the touch screen lock switch.
While holding the Volume up button, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
Once the tablet screen turns on, stop holding the buttons.
On the Android system recovery <3e> screen, select wipe data/factory reset. Use the Volume up and Volume down keys to navigate through the menus and use the Power button to select the desired option.
When prompted to "Confirm wipe of all user data", select Yes -- delete all user data.
Select reboot system now.
Mar 21, 2015 | Acer Tablets & eReaders
When I try to refresh my tablet it won't work
You need to reset it by pressing the on button, and at the same time keep tapping the volume up several times till you see the little Andy Android come on and stop. This will reset your tablet. Good luck.
Mar 17, 2015 | Nextbook Next3 tablet
What happen to sound on kocaso tablet
Check you have not accidently turned down the volume.
Adjust the volume by pressing volume +.
Apr 27, 2014 | Kocaso Tablets & eReaders
Nobis tablet turns off and on but all else does not work...no screen with app..states everything has stopped working
Sounds like you have some type of software corruption. What I'd do is try to factory reset the device. This will wipe the tablet, but at least you'll have it working again!
To factory reset your phone, Just follow this simple steps below: *Turn off your Tablet *Press and hold Power key and Volume down key at the same time *Release the keys when the recovery mode appears, then navigate using volume up key to Wipe All user data and use the power key to select that option *Wait for a DONE message that will appear in your phone. *Then restart your phone using the power key. Done!
Apr 22, 2014 | Nabi 2
Tablet m1050s the TTS Engine stopped working
try factory reset from power key & volume and main key but watch out it will eras every thing (hard reset)
Oct 21, 2013 | Kocaso M1052S 10.1" Android 4.0 Tablet PC
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
Aug 24, 2013 | Acer ICONIA Tab W500PC52G03iss
My Fisher Digital Tablet 7.1 completely stopped working, all the applications already in the tablet won't turn on "Google Market" or anything for that matter. Pop ups saying everything has stopped
I AM HAVING THE SAME PROBLEM, MY FISHER DIGITAL TABLET 7.1 HAS FROZE ON THE INTRODUCTORY SCREEN, I HAVE TRIED THE HOLD VOLUME BUTTON DOWN+POWER BUTTON AND STILL DOES NOT WORK, I HAVE HELD THE POWER BUTTON, PLEASE HELP ME! I HAVE ONLY HAD IT 2 DAYS! :(
Jun 12, 2013 | Fisher Digital New Tablet Pc Android 2...
Tablet wont load fully
Try taking your battery out and then put it back in. Hold power plus volume and scroll to recovery.
Jun 02, 2013 | Tablets & eReaders
Diamond Multimedia S3 Trio 64 86c764x 9550 fa2354 Stealth 64 DRAM T PCI 2MB VGA Graphics Accelerator Video Card - v 2.09 - Expandable to 4MB Logo
Top Diamond Multimedia Computers & Internet Experts
David
David
Lawrence Oravetz
Are you a Diamond Multimedia Computer and Internet Expert? Answer questions, earn points and help others
