Question about Farberware 12-Cup Food Processor w/ 4-Cup Nested Workbowl,
Can't take apart for cleaning - Farberware 12-Cup Food Processor w/ 4-Cup Nested Workbowl,
Why doesn't it turn on after cleaning and reassembly?
Yes it is everything to do with the side springy things. Get a torch and look inside there is a blocker on one corner, it needs to be lined up with the missing corner on the carbon brush.
Apr 12, 2016 | KitchenAid KSM150PS Artisan Series Stand...
I have a Uniworld UPM-20E commercial mixer. I bought used from another baker and it was working when I bought it.
Electric devices get damaged sometimes by internal corrosion even if you don't use them. If you have the technical knowledge, take apart the control board or control panel, probably you've got some contact problem. you might be able repair it by cleaning or maybe you might need some part to replace.
If you don't have real knowledge repairing this kind of an appliance, my best advice: take it to a repair service.
Some time ago I tried to do a similar job with my home mixer and had to take pieces in a shoebox to a repair service ; I took it apart, cleaned contacts bur couldn't assemble it againbecause after taking it apat, couldn't assemble it again
Aug 20, 2015 | Uniworld UPM-20E 20QT Commercial Planetary...
Take apart kitchenaid dicer
One of these two Service Manuals will, most likely, give you the answer:
Professional 5/6 quart
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
Classic 4.5/5 quart
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Oct 10, 2014 | KitchenAid Food Mixers
Why won't our kitchenaid stand mixer run?
He rdnowak:
I am sure #10 in the highest speed, but are you saying it will only run at #10? if so I would start by removing the cover again. Hopefully no parts are missing. Make sure the selector switch is moving things on the board if possible. I mean if you can move it with you finger you should be able to move it with the selector lever. Sorry for the trouble but I have never taken mine apart I just clean the out side. I do no this. Sometimes I must take something apart and reassemble them several times before getting them to work the way they are supposed to.
Best of luck
'RR
May 15, 2014 | KitchenAid Pro 600 Stand Mixer KP26M1X-...
Kenwood repair KM400
if your circuit board got a little wet . you might check into that for residue must clean with baking soda solution and toothbrush clean area or brake cleaner might dissolve the residue too ...speed control is just a resister band . and if very old can be worn down like a climate control in a car ...
Mar 23, 2014 | Food Mixers
My mixer worked fine, I took it apart for a really good cleaning and now it won't work at all. Please show me how to take it apart & put it back together correctly.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers your model. Pay attention to the Motor Brushes, making sure
they are maiking contact with the Motor after re-assembly.
Aug 15, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Was just givin a hobart a200 was in a school warehouse for at least 1o years attach.shaft and seals replaced by hobart 6 month before put in storage runs great smooth no gear noise BUT fromm sitting bowel...
Ogrin56,
The problem is in your lift handle cams, you need to take the pedistal apart and clean and grease all the cams. I take them apart and wire brush them and use white lithium grease to keep them from freezing up.
Feb 26, 2011 | Hobart A200 Stand Mixer
Put kitcheraid meat grinder back together
Proper assembly of the Food Grinder Attachment is covered in the attachment's Use and Care Guide.
Jan 11, 2009 | KitchenAid Food Mixers
Oster Kitchen Center won't hold a steady speed
My wifes Oster Kitchen Center slowed down and I think finally stopped. I say I think it did because I took it apart two years ago and am finally finding the time to get it back together. I cleaned it, checked the brushes on the motor(all of this is in the base unit with the control buttons on it. The upper blender/beater arm has no electrics in it.) The brushes were coated with some kind of dried crusty stuff which was keeping them from contacting the motor.I put it back together and tried it but it only hummed and did not move.
I took it apart again, this time everything came out. Motor, electric wiring plus the metal gearbox attached to the motor which drives the blender and the upper arm. I took the transmission apart (it's attached to the motor in the base unit) and found the gears in it were so gummed up with who knows what. Probably everything that leaked out of the blender.
You see, what happens is that the seal between the blender black base and the glass jar started to leak after a few years but we don't notice it. Maybe we did but we cleaned it and we thought it was all good. But the liquid can leak down into the bottom unit around the drive teeth and that little square drive that the blender locks onto. And then it goes into the gearbox and the motor. So it is a major job to clean it. Since I don't have a manual for disassembling the lower base unit, I'm just putting it back together. I cleaned all the gunk out, put some grease on the gears and the gearbox is working better but I fear not perfect. It is 30 years old!! So unless you take it apart yourself or find an appliance repair shop (is there such a place anymore?) it might not be worth the effort. But it is do-able. How long have you got?
Mar 01, 2008 | Food Mixers
Farberware 12-Cup Food Processor w/ 4-Cup Nested Workbowl, Logo
23 people viewed this question
Top Farberware Food Mixers Experts
eyecam
Are you a Farberware Food Mixer Expert? Answer questions, earn points and help others
