Question about Qca Spas Paradise Series Paradise Supreme Xlp Hot Tub
Cannot get summer lock off caldera martinique
Caldera olympia highland spa keeps tripping breaker
with power off take heater wires off make sure to mark them so you know which is which if it doesnt blow fuse it is heater element if it still does hook back up then try to disconnect the recirculation pump just keep eliminating things
Mar 02, 2014 | Caldera Spas Highland Series Olympia Model...
I am principal at the Petite Martinique R. C. School on the island of Petite Martinique in Grenada. We have a brother mfc-9450cdn printer. We are currently experiencing problems with the printer which...
The error "print unable 20" is normally caused by a Hardware/Electronic error: a 'printing' laser 'diode' is not working. I am afraid that you may need to get it fixed, hopefully under warranty: contact your local Brother Printer service centre for instructions.
May 03, 2011 | Brother MFC-9840CDW Laser Printer
Is there any way to fix the Delta Martinique 5-in-1 Crib so the side can no longer drop down or do I need to get rid of the crib all together?
Delta will send you the repair kit to fix a crib that was recalled. Click this link to go to the Delta Recall website, and enter the model number to start the process:
http://www.cribrecallcenter.com/step2.asp?recall=2&co=1
If you have any trouble with the online entry form, you can email them directly at:
questions@DeltaEnterprise.com
Jan 27, 2011 | Delta Martinique 5-in-1 Crib
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
how on earth is this related to gaming consoles or PS3 ??
Please post under correct sections next time.
Anyways, it looks like a common problem for the Triton Shower, and it might cost you some $90 to fix it.
http://www.comparestoreprices.co.uk/showers/triton-martinique-10-5kw.asp
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
Where can i get the toddler rail for the delta martinique crib?
As far as I know that is one of the draw backs to this particular crib is that you can't purchase a rail for the toddler bed specifically made for the bed. I'm still trying to locate the full size bed frame for it. I knew it was a purchase separately, but I didn't know if it was one that a general bed frame could go on.
Aug 30, 2009 | Delta Martinique 5-in-1 Crib
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
Want to install xp instead of vista - but end up in caldera dr dos
Alot of the reason is because they don't want you to down grade from Vista to XP. But see if this helps. Start your pc, insert XP disk, as soon as the screen comes up press f12 which will allow you to choose the booting sequence, click CD- ROM and the disk should start to be read. understand this tho by downgrading you will have a hard time finding the appropiate drivers for most of your devises since they were meant to be runned by Vista. Here's a tip go find the drivers in europe (be it toshiba.europe, Dell.europe) for they are still running XP. to find the drivers for your particu;ar pc just find the series number and the last unit to run with xp and viola a working xp on a vista pc. Hope this helped
Good Luck =)
May 30, 2009 | Microsoft Windows XP Professional SP2
Want to install xp by caldera dr dos
The problem is hard enough for beginners . First :
1.DR DOS is used by ASUS . DR DOS isn't MS-DOS (Microsoft), just 99% compatible with it . You have access with it on whole HDD+cd/dvd but , because drdos will enable only 8MB RAM you can't install winnt.exe from i386 . There are at least 2 solutions :
a. if drdos is enable because u reseted BIOS try to change bios according to a better result (avoiding Caldera) and start a nice windows installation;
b. u may use another desktop/laptop until the first restart (in installation) ; u must try to use a computer with ~motherboard for best results.
Don't forget that DR DOS Caldera is almost every time used on ASUS MBs with all on board and you must have a PS2 keyboard/mouse to use any kind of DOS . I read sometimes that DRDOS is a soft used by Microsoft which it's wrong - there isn't any link between drdos and any windows system , genuine or not .
DRDOS problem might appear because it's a soft put on ASUS MB cd driver and , sometime, might be on a BIOS ROM .When u will boot with the MB cd driver in this kind of problem might occur .
Other way Caldera may appear is when u have a windows cd made careless with NERO and caldera will appear no matter the MB .
Mar 24, 2009 | Microsoft Windows XP Professional SP2
Qca Spas Paradise Series Paradise Supreme Xlp Hot Tub Logo
43 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
