Question about Pogo Moon Stick
Moon stick rubber tip worn - Pogo Moon Stick
2003 saturn vue
Perhaps it's still tired from the previous night and hasn't had appropriate levels of caffeination. Check voltage at the fuse circuit and all appropriate points along the circuit path. Check for both blown AND simple worn fuses....which won't carry the full current and could potentially cause a noticeable drop in voltage leading to the sluggishness. Similarly, make sure there are no broken or worn wires or connectors along the circuit path.
But before any time is spent delving into potential electrtical sources for the poorly performing moon roor, thoroughly clean out carefully examine the track and areas the roof moves from A (close) to B (open) for obstructions like leaves/debris, dents or small buckles or flares in the body, damaged seals and worn rubber gaskets.....basically anything that could cause an obstruction or slow the open/closing action......
Finally, if nothing comes of these first 2, carefully test the motor/drivers that power the movement of the moon roof.
And lubricate, lubricate.......LUBRICATE!!!!
Jul 06, 2014 | Vehicle Parts & Accessories
Where do you get a moonstick replacement tip
just go to hardware store they have many rubber tips
Jun 22, 2014 | Pogo Moon Stick
Can I buy a new rubber tip for my pogo stick?
yes, you canreplace just the rubber tip on pogo sticks at places like Amazon http://www.amazon.com/Foam-Master-Rubber-Pogo-Stick/dp/B005ONKDRSMake sureyou know what type of tip you want before you buy.
Aug 01, 2012 | Sport & Outdoor - Others
Is it dangerous to use a pogo stick?
It's notdangerous to use a pogo stick if you follow some safety rules to reduce therisk of injury:
  • Always weara helmet
  • Always wearshoes
  • Never useyour pogo stick without a rubber tip
  • Make sureyou keep your stick clean and change any worn out parts
  • Only useyour stick on hard surfaces
Pogo moon stick doesnt bounce. How do u get it to bounce
I bought it too it didn't work either but I'm only fifty pounds so, my grandma tried and she is 135 pounds and it worked so, GAIN MORE WEIGHT!
Jun 17, 2012 | Pogo Moon Stick
Brand new just tookout of container and wont stick to windshield
Sometimes the rubber plunger plastic/rubber new is not worn in yet, take rubber plunger part off, soak in warm water for a few minutes, then bend it in just a few times, put a dab og saliva on it stick it on and push lever back firm, twist suction cup some before putting lever down to secure it. If this helped, please rate with 4 thumbs , to help me and others. Thanks mike from fixya
Jun 16, 2011 | GPS
Hi what can cause the engine oil to push out from the dipstick plaese assist thanks John
Hello John. It might seem like your stick's ring (that rubber stopper that acts as a seal) has worn out. You need to replace the rubber seal or ring. If that cant be done, then perhaps getting another deep stick will help you solve it.
Dec 03, 2010 | 2002 Land Rover Freelander
I need replacement bands for shoes that are frayed
http://www.bigtimetoys.com/contact.html Big Time Toys, LLC
708 Berry Road
Nashville, TN 37204
Moon Shoes Replacement Rubber Bands
Send a check for $7 to Big Time Toys at the above address for a pack of 50 replacement rubber bands.
Oct 23, 2009 | Kb Toys Moon Shoes
Moon roof leaking tube in corner stopped up.
If you can access the top side of the tube without removing the moon roof, you can take an air compressor hose with a rubber nozzle, jam the tip in the hose and blast it with quick bursts of air. To insure that you got the blockage out, pour some water in that area and watch around the wheel well for the water to flow out.
May 27, 2009 | 2006 Land Rover LR3
Pogo Moon Stick Logo
Top Pogo Toys Experts
ray gallant
Are you a Pogo Toy Expert? Answer questions, earn points and help others
