Question about InFocus LP70+ Multimedia Projector
Infocus LP70+ has a small shadow in the right lower corner of the display. Could this be a bulb or lens problem or ??? Thanks for any help suggestions.
  • vfrdave Oct 29, 2007
    Where is the mirror? Is that the thing at the bulb which rotates?
     I took it to a guy who works on projectors who thinks it is the DLP chip or somewhere on the board, as pushing on it changes it and also starts and stops a flicker? Estimate to repair at a service center is $750, which is more than a refurbished unit cost. So I am still interested in fixing it, just don't want to kill it by poking about with it on. Thanks
  • 2,237 Answers
The light tunnel is collapsing. it's used to hep evenly distribute the light and make the edges crisp. infocus now calls it an integrator rod (315-0055-xx).
to replace the tunnel (rod):
take the top off, take the screws out of the top and the wires out of the circuit board, take the fans out, take off the colorwheel shield, remove the lens assembly (optical engine), remove the colorwheel, take out the 3 set screws, and slide out the tunnel assembly. then remove the foil around the opening and the screw out of the top, and slide the rod carrier out. now remove the metal clip and the pieces of mirror. replace the tunnel (rod), put the clip back on, and reverse the procedure. now, the 2 set screws on the side are to adjust the image, so do not put them in too tightly, and they must be adjusted while the projector is on and the cover is off.
or give it to someone else to do.
Posted on May 14, 2009
    Problem Solver:
  • 3 Answers
I had the exact problem and of course , I have no manual or instructions for my InFocus LP70+ Projector. I fixed the problem by accident! THIS WILL WORK!! Using the control buttons on top of the projector, Go to the menu on the screen, Go down to setup and press source select, then to Picture and press source select, Go down to position and press source select, you will see H___V___ , select the H (for horizontal) and adjust up or down until the shadow goes away! This cured my shadow on the right side and in the lower area.
Posted on Mar 17, 2008
I was just given 3 of these projectors to take a look at to see if I could fix. The problem is definitely related the mirrors as previously stated. I have actually removed the mirrors and got all three working again. There seems to be a slight affect in brightness but other than that all seems well.
Hope this helps someone...
Thanks,
Gary
Posted on Jan 08, 2009
    Sergeant:
    Champion:
  • 341 Answers
I tried to pry it up and it's right in front me now dissasembled. There is this box-type light tunnel set of mirrors and the glue wasn't able to hold it now. no wonder, jarring it sometimes helped.
so it's the adhesive of the mirrors that did not withstand the heat. maybe infocus should order glue from selley's or the like.
I hope i can assemble the mirrors perfectly at right angles. These are about 1-inch i length by 3/16-inch for the two sides and 5/16-inch for the wider sides.
well, this would be the last time i will buy an infocus...let's see if they can have a better glue in ten years! so there you are...
Posted on Jul 18, 2008
  • jhun T
    jhun T Sep 25, 2008
    sorry for the delay...
    the mirrors I mentioned is located inside the metal tunnel fronting the round rotating cover (might be a glass). You have to loosen the hex-headed screws to remove the mirror holder. I tried to glue it back myself using an instant glue/cement. I haven't heard back from the user lately...it might have worked.
    gudluck!
I had this problem with the frist unit, then we sent it back to them. Now after using the new one for a few month its doing the same thing in the right corner.
Posted on Feb 05, 2008
I too have this problem, and it has slowly grown to extend almost all of the way up the right side of the screen. I have reseated the bulb assembly, and checked for dirt on the lens - but no change.
Posted on Oct 12, 2007
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
I have a 6year old infocus LP70 projector. its footstopped gripping, so i opened the case and bodged a permanent pastic knob to keep at an APPRPRIATE LEVEL - BU i SEPARATED TWO WIRES ON THE LINK BETWEEN...
if you are talking about the ribbon connection on the rear of the main board, then yes I would scrap it unless you want to try and find a LP70 on E-bay to use for parts. You may or may not get a good board but if the price is under 50 bucks it may be worth the risk.
Oct 16, 2010 | InFocus LP70+ Multimedia Projector
I've had my projector for years now and worked perfectly. But now, there's a shadow on the right side of the screen. I cleaned the lenses and there's still a shadow. With my observations, it looks like...
Remove the bulb, look for any obstructions or damage. If you see none. Replace the bulb, usually replacing the bulb also replaces the lens, the frame around the bulb, and other components all at once making it an easy one stop fix for most visual display problems.
Jun 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
LP70 infocus projector is casting a shadow on the left side of the screen. It seems as if something is blocking the lens from inside? Could this be a bulb issue?
the light tunnel is collapsing and need to be replaced. you could get the part from an infocus service center and do it yourself or send it in to one and have them repair it. speaking from experience, it's a quite involved repair. you have to basically take the whole thing apart to get to it, and make adjustment to it really close to the power supply while it's on. kinda risky. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 15, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
Shadowing on lower right of screen on InFocus LP70+
the light tunnel (like a square tube of mirrors) is collapsing. it needs to be replaced, but it's a bit involved, so and infocus service center would be your best bet. if you wish to try it yourself, let me know.
Jul 14, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70 Won't display Top 3/4 of screen even with new bulb
if the colorwheel stopped spinning, the projector would shut off. take the lamp out and spin the colorwheel (with a pencil eraser) to the clear section and look at the square on the other side. if it's not a complete square or something is inside the square, your light tunnel is collapsing and needs replacement (also called an integrator rod).
Jul 08, 2008 | InFocus LP70+ Multimedia Projector
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
Infocus X1A Projector
This is a very common issue with the Infocus projectors. Sounds like the mirror tunnel that sits right behind the Color Wheel and concentrates the light source onto the DLP chip. This tunnel which is shaped like a small prism is very fragile and can "fall apart" over time. Some have attempted to try and remove the tunnel and repair with limited success. Otherwise you may either need to send the unit in for repair or find a dealer who can order the part for you.
Here is another who had the same issue;
http://www.fixya.com/support/t401456-infocus_x3_video_problem
Mar 14, 2008 | InFocus X1 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
1,514 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
