Question about GT Avalanche 3.0
How to raise handle bars - GT Avalanche 3.0
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Posted on Jun 03, 2015
How do you raise the handle bars on the bike?
If it is an older bike, you loosen the bolt at the top of the handle bar shaft until it is about 1/2 inch raised. Take a hammer and give it a swift bump and it should drop into the shaft. Hold the front tire between your legs and the handle bar should raise up. Re tighten once every thing is lined up. If the bike has front hand breakes these may need to be adjusted.
Aug 05, 2014 | Generic 16" Raskullz T-Rad Rex Boys Bike
you cant raise the handle bar but you can add spacers to increase the height.Wish we could be able to raise the handbar
Jul 06, 2014 | Genesis 26 Inch V2100 Dual-Suspension...
Can not raise the handle bars on the Huffy Mojava Gulch?
You need to loosen the front bolt that holds the handle bars to the front wheel raise it to your desired position and then tighten it again, making sure that the handle bars are at the position you desire them. This will lock them in place so you can ride your bike and not let them fall back down deeper into the front wheel shaft.
May 11, 2011 | Huffy 26 In Ladies Mojave Gulch Bike
Can I raise up the handle bars on my 26" Ladies'
No, but a bike shop can assist you in selecting and fitting a stem with a higher rise.
Feb 24, 2011 | Columbia Sportswear Columbia 26" Ladies...
How do i raise the handlebars?
There are two bolts in the center of the handle-bars. One bolt (on some bikes this is actually 4 bolts) is used to clamp the handle-bars to the handle-bar-stem. You can see both ends of this bolt. If you loosen it, you can tip the handle-bars up and down, but not raise them. The other bolt you can only see the head of. Loosen this a couple of turns (don't unscrew it all the way) then give it a tap with a hammer. You will then be able to pull the handle-bar-stem completely out. Do this so that you can see the wedge-shaped nut at the other end of the bolt. You should also see a mark on the stem that indicates how high you can safely raise the stem. Put the stem back in to the desired height and tighten it back up. Good luck.
Jun 11, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
Schwinn Impact MOS.....can the handle bars be raised? If so, do you loosen the small star nut on top, or the large nut at the base of the handle bars?
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
May 22, 2010 | Cycling
Need to raise the handle bar on my 2007 Marin Argenta road bike.
The stem for the marin is fixed so you'd have to replace it with one that is higher if you wanted to raise the elevation of your handle bars. You can pivot the handle bars for your preferred angle of comfort though. Loosen the 4 screws on the top of the stem and then you can adjust the handle bars to the correct angle that is best for you.
Jan 09, 2010 | Cycling
Handle bars adjustment - want to raise the handle bars
You will have to go to a bicycle repair shop and ask for a handle bar stem extender. They come in various lengths.
Nov 29, 2009 | Jeep Wrangler X Mountain Bike
Bike gears
usually there are 2 levers on each handle bar, one lever lowers the gear while the other one raises the gear. usually the right handle bar has the shift for the gears on the rear wheel, while the left handle bar has the shift for the pedal gears
Oct 08, 2009 | Cycling
GT Avalanche 3.0 Logo
102 people viewed this question
Top GT Cycling Experts
tomar33
ray gallant
David Payne
David Payne
Are you a GT Cycling Expert? Answer questions, earn points and help others
