Question about Garden
Komatsu Zenoha hedge trimmer HT230A fuel mix - Garden
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
trippssmengi
  • 76 Answers
SOURCE: oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
Posted on Jan 18, 2009
  • 97 Answers
SOURCE: how to put new fuel hose into fuel tank
You will need to split the fuel line for about 2 jnches and push it through the hole then reach in the tank with needle nose pliers and pull it through.Then cut off fuel line square and install filter.
Posted on Mar 19, 2009
panilling9
  • 284 Answers
SOURCE: HT-17 Hedge Trimmer Fuel Ratio?
I use 40:1 in mine always have works perfect 3.2oz of reputable 2 cycle oil to one gallon of fresh gas
try to find the oil that has fuel stabilizer already in it
Posted on Jun 12, 2009
  • 28 Answers
SOURCE: Husquarna petrol hedge trimmer starting problem
it could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Posted on Aug 06, 2009
My HS 45 seems to drip oil while cutting, I think it is damaging plants. Is it because there is too much oil in the fuel mix?
Fuel mixture for that model is 50 to 1. Stihl also sell their own premixed fuel and oil which is Ethanol free and non aromatic.
I wondered if it has a blade oiler, but it doesn't. I does however have a gearbox with oil in it. I wonder if it is leaking. Do you know where the excess oil is coming from?
You model is listed here and the Manual and details of the fuel are on his page.
STIHL HS 45 HomeScaper Series Hedge Trimmer
Oct 04, 2016 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
Hedge trimmer
possible problem with dirt or blockage in the main jet of the carby
remove carby and blow out all holes and jets
fit new diaphragm
ensure that the oil / fuel mixture has not excessive oil in the mix
do not use e-mix fuel
Aug 10, 2016 | Tanaka Hedge Trimmer Tht-2100 Trimmers...
What is fuel/oil mix ratio for ht22 hedge clipper
50 to 1, 20 ml per liter or 2.6 fluid oz per US gallon
Sep 19, 2011 | Homelite Factory Reconditioned 26cc...
My 10 year old weedeater hedge trimmer ran fine last year when I put it away for the season. When I tried to start it this year it wouldn't even fire. I put fresh fuel mix in and a new spark plug and...
I would check for spark and check the fuel lines, especially if fuel is left in it. Also if fuel left in you will have to empty the lines and carburetor or pull it enough to clear. Another thing to consider is that if fuel was left in it that the carburetor may need a rebuild, replacing the diaphrams.
I hope this is helpful for you.
Aug 19, 2011 | Weedeater 19 in 25cc Gas Hedge Trimmer
How do i workout the fuel mix for my plt2543y strimmer
Oil gas should be mixed in the ratio 1 to 50 or 2%
That's 20 mL in 1 litre or 3 fluid ounces per US gallon of gas.
Jul 28, 2011 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Need to know fuel mix for mcCulloch gladiator 550 petrol hedge trimmer
I don't know the age of this machine, but more and more of the newer units are using a 50:1 mix to satisfy the newest EPA emissions regulations. I suggest using a synthetic or synthetic blend of 2 stroke oil. ....the big box stores sell the oil...Echo one of the best. I would use synthetic and mix it 40:1. Here is a fuel mix chart to show you how many ounces of oil in a gallon of gas that is. If you make a 1/2 gallon batch of fuel mix, just use half of the listed oil amount for the mix.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
40:1 is 3.2 ounces of oil in a gallon of gas...or 1.6 ounces of oil in a half-gallon of gas
Jul 04, 2011 | McCulloch Garden
What is the current oil/gas mix for the excalibur 22" hedge clippers? How about the new oils like Echo an Brigg/stration that are used at 50/1. Would 50/1 be acceptable in the weed eater excalibur?
50:1 is 50:1 no matter whose 2 cycle mix you use. 50:1 is 2.6 ounces of 2cycle mix to 1 gallon (US) of gasoline. I recommend strongly to use a brand that contains fuel stabilizer. It will come in a 3.2 ounce bottle...still 50:1. The premium 2 cycle oils will be semi-synthetic or full synthetic and will claim "no smoke"
Sep 27, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Hedge trimmer wont fire
check spark plug, H T lead ,carb , clean fuel mix, air ful ratio.
Jul 18, 2010 | Craftsman 22" Gas Hedge Trimmer
Fuel mix for ALKO RT250 strimmer
Mix one ounce of 2 cycle oil per quart or 4 ounces of oil per gallon of unleaded gasoline. Hope this helps and best wishes.
Aug 28, 2009 | McCulloch Lawn Care: Trimmer Plus...
Craftsman Hedge Trimmer model 358.796353 that won't operate
The problem you are experiencing is the coil. I had the same problem and confronted a freind that works on small engines. I asked him if the coil could be the problem and he gave me one to try out of another trimmer he had for parts. It is running well. The problem I now have is the blade tang that moves it back and forth broke. Now I'm trying to locate one of them.
Mar 28, 2009 | Craftsman 22" Gas Hedge Trimmer
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
