Question about Uniden BCT7 Base Scanner
How to reset scanner - Uniden BCT7 Base Scanner
How to reset my Uniden BC75XLT Bearcat Scanner .
Resetting the Scanner
If the scanner's display locks up or stops operating properly,
you might need to reset the scanner.
CAUTION: This procedure clears all the information
you have stored in the scanner. Before you reset
the scanner, try turning it off and back on to see if
it begins working properly. Reset the scanner only
when you are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the scanner.
It takes about 3 seconds to initialize and CLEAr appears.
Jul 08, 2014 | Uniden Bearcat BC75XLT Police Scanner
Scanner stuck at 000.0000 keys don't work
You may benefit by performing a reset or initialization of the scanner. The manual describes the procedure at the bottom of page 38.
You may lose previously stored frequencies if you reset or initialize the radio.
RESET
1. Turn off the scanner, then turn
it on again.
2. Insert a pointed object, such
as a straightened paper clip,
into the reset opening on the
side of the scanner. Then
gently press the reset button
inside the opening.
Initialize
it on again.
2. Hold down TUNE/CLEAR.
3. While holding down TUNE/
CLEAR, insert a pointed object
(such as a straightened paper
clip) into the reset opening on
the side of the scanner, then
inside the opening. The
display should turn off.
4. When the display turns on
again, release TUNE/CLEAR.
I hope this helps & good luck!
Feb 04, 2013 | Radio Shack Pro-82 200 Channel...
HOW DO I RESET A CORDLESS SCANNER HONEYWELL 3820?
I believe you can print the documentation and scan a bar code to reset the scanner. You can get the documentation here: http://lib.store.yahoo.net/lib/barcodescannersdiscount/3820UserGuide.pdf
Press CTRL+F and type "reset" to find sections on resetting the scanner.
Mar 02, 2011 | Honeywell 3820 Wireless Handheld Barcode...
I have pro 135 from radio shack. How do I reset it and keep the channels that are programed in it?
The RESET function will clear everything that you have programmed into the scanner and restore original factory settings. You can, however, restore the 150 pre-programmed frequencies after a RESET.
To RESET:
- Power the scanner OFF.
- Hold down the 2, 9, and PSE keys and power the scanner ON.
- CLEAr appears on the display as the scanner resets.
- Do not power the scanner OFF until CLEAr disappears from the display.
To restore the original 150 pre-programmed frequencies:
- Turn the scanner power OFF.
- Hold down the 3 and ENT/PGM keys and power the scanner ON.
Bill B
Apr 28, 2010 | Radio Shack Pro-82 Scanner
After I enter a frequencie the enter button doesnt work to enter
If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
To RESET:
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
MY 2096 BASE SCANNER READS ALL CHANNELS LOCKED AND I CAN'T UN DO IT AND OPERATE NORMAL. HOW DO I CORRECT THIS PROBLEM?
If all else fails, and it sounds like it has, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
BillB
Jan 24, 2010 | Radio Shack Pro-2096 Base Scanner
All channels locked
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
BillB
Jan 23, 2010 | Radio Shack Pro-95 Handheld Scanner
My pro-2096 does not display any letters or
To RESET:
- Press ENT
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
All channels are locked out. how do I get them unlocked
To RESET:
- Press ENT
BillB
Jan 22, 2010 | Radio Shack Pro-97 Handheld Scanner
I TWON'T MOVE. IT SAYS ALL CHANNELS LOCKED OUT. NEED HELP
If all else fails you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Press ENT
BillB
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Uniden BCT7 Base Scanner Logo
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
