Question about Mk Diamond MK - 101 Pro 24, 2hp Tile
I have a superiorbilt 10 in wet saw and I need to find the flange that the blade rests against . Mine is not useable. Any help on locating parts will really be appreciated.
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Posted on Apr 27, 2010
Why can't I tighten replacement blade sufficiently?
Check the diameter of the replacement blade hole against the removed blade. Similar blades can have different size mounting holes.
Sep 17, 2015 | Saws
Superiorbilt 10" wet tile saw parts
Take a look on amazon for them, here: Amazon com wet tile saw parts. Wish you best of luck.
Thomas
Oct 04, 2012 | Mk Diamond MK - 101 Pro 24, 2hp Tile
I need to rplce the blade on a 10 inch wet saw. The nut is extremely tight and I want to make sure I am turning it in the correct direction. If I want to loosen the nut, do I turn it in the opposite...
In most tile saws it is a clockwise thread for tightening, and anti-clockwise to undo the nut (from looking at the blade with the nut facing you) If you have a vice it is sometimes best to clamp the the blade into the vice with the tool resting on top, to help when undoing the nut. Take caution when doing this, do not over tighten the vice as it could buckle the blade and as always when changing a blade disconnect the tool from any power supply. Hope this was of help to you.
Jan 22, 2011 | Saws
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
10'' table saw binding?
Sounds like you lost a spacer that goes behind the first flange against the motor bearing, you could use a lock washer if you bend it flat.
Assemble:
spacer washer,
first flange,
blade,
second flange,
nut.
I think the first flange is rubbing the motor housing.
Apr 26, 2009 | Saws
How to change blade;where is button to hold blade from moveing
There is no button to lock the arbor on a table saw. One method is to take a piece of wood, about 1" x 1 1/2" x 16" long, rest it against the back or front of the table throat and lever it against the blade, holding the blade from spinning while you use the wrench to loosen the nut on the arbor.
Make sure you first unplug the saw before changing the blade. Lever against other end of throat while tightening.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 04, 2009 | Craftsman 10" Table Saw
Replacing the blade on a Makita 255mm miter saw
I take it you have both flanges and the washer that is behind the innner flange, if not stop there and you need to get them. As far as the blade goes it depends on what size arbor it has. You would need to use the washer that goes on the spindle with no play (movement) and put the blade on the washer I would not use a washer that is thicker than the blade. Put the outer flange on making sure of the direction and then the blade bolt LH thread. Let me know if you have any problems before starting the saw PLEASE and I will help more.
Feb 17, 2009 | Makita 10" Miter Saw LS1030N
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Dewalt 708 sliding compound mitre saw
Probably a worn bearing. The only other thing that I have seen cause this is a bent spindle. This would usually occour if the machine has had an impact or if the blade has been suddenly jammed against a nail or something in the work that has caused it to jam and/or jump up.
A good indicator for bearing wear is to see how much play is in the blade in an up/down and side to side movement (unplug saw, safety first).
To check spindle, remove blade and run machine without the flanges etc on. Rest a scredriver gently on the shaft as it spins and see if you notice any (uniform) vibration.
Oct 07, 2008 | Saws
Mk Diamond MK - 101 Pro 24, 2hp Tile Logo
46 people viewed this question
Top Mk Diamond Saws Experts
JonSnell Electronic
JonSnell Electronic
Regalo Tiles
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
