Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson photo r2000 inside paper jam - Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
doc_delphi
  • 11 Answers
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
Posted on Sep 17, 2008
57 varieties
  • 1653 Answers
SOURCE: EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
Posted on Aug 29, 2009
virtualhost
  • 2185 Answers
SOURCE: Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Posted on Sep 20, 2009
Testimonial: "tried blowing and dusting with a brush Now it comes on as normal - no flashing light but will only take paper about 2 cms then flashes paperjam"
asabur
  • 102 Answers
SOURCE: Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
Posted on Jan 03, 2010
Testimonial: "many thanks for your reply - looks like is could be expensive (more expensive than replacing the printer?) i'll take it to an epson repair center"
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
I have an Epson stylus photo PX 660,which is displays an error message that,paper jam inside and in real sense there is no any paper jam inside.show me how i can solve this problem.
Check the rollers (the inlet and outlet for the paper) and blow them out with a blower,vacuum, or a can of air. That should "fixya" right up. Lmk if it doesn't and I'll get down to specifics with more info from you as well
Feb 12, 2015 | Epson Stylus Photo Px660
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Paper jam
From the reference manual for your Photo Printer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
"Epson Stylus Photo R220 Series Printers"
The Paper Jams
Press the font29.gif paper button to eject the jammed paper. If the error does not clear, turn the printer off, open the printer cover and the CD/DVD guide. Remove all of the paper inside, including any torn pieces, then close the CD/DVD guide. Reload the paper, then press the font29.gif paper button to resume printing.
r_note.gif Note: r_space.gif If you cannot remove a foreign object easily by yourself, do not use force and do not disassemble the printer. Call Epson for assistance.
If your paper jams frequently, check the following:
  • The paper is smooth, not curled or wrinkled.
  • The paper is of high quality.
  • The printable side of the paper is face up in the sheet feeder.
  • The paper stack was fanned before loading.
  • The paper is not loaded above the triangular load-limit mark on the left edge guide.
  • The paper stack fits under the tabs inside the edge guides.
  • The number of sheets in the paper stack does not exceed the limit specified for that media.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jam has been cleared, but paper jam message remains.
Try these steps and see if it resolves your problem. Hope it helps:
Follow these steps to clear a paper jam:
  1. Press the cp_button_45_er.gif Start button to eject the jammed paper. If that doesn't work, go to step 2.
  2. Turn off the Epson Stylus.
  3. Lift open the scanner and remove any paper inside, including any torn pieces.
  4. Close the scanner, then turn the Epson Stylus back on.
Aug 02, 2009 | Epson RX595 Photo All-In-One Printer
Paper jam, with no paper jam!
try to re open again your machine and look very carefully inside remember even how small the paper it will still cause for a paper jam.
if not try to send it to a service technician to give a look to the printer head and rollers.
thanks,
Jun 14, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
