Question about Jenn-Air 35 in. JGC9536 Gas Cooktop
5 burner kleenmaid gas cook top igniter stays clicking on
SOURCE: spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Posted on Mar 09, 2009
  • 530 Answers
SOURCE: My burner sparks though my burners are off
did you spill liquid on the cooktop? sometimes if you just let it sit for a few days to let it dry out it will fix itself. but if you spilled oil on it it will not fix itself. you have a bad spark module and the only way to fix that is to remove the cookyop fromt he burner box. and find where all the wire go into this usually redish orange box sometimes its blue. but that is your spark module. let me know if you have any more questions
Posted on Jun 02, 2009
  • 222 Answers
SOURCE: turn on one burner, second burnertrise to light
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
Posted on Sep 16, 2009
localwonder
  • 6784 Answers
SOURCE: all cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Posted on Nov 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: Sealed gas cooktop. Igniter keeps clicking.
I have 2 videos for you:
Burner replacement
Burner switches
Posted on Dec 19, 2009
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
We can't turn off the igniter on our gas cook top
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Mar 27, 2011 | Wolf Range RHP-6-36 12 in. Gas Cooktop
The igniter on my gas cook top won't shut off.
heatman101
Jan 27, 2011 | Jenn-Air Cooktops
Gas ignitor keeps trying to ignite after stove is off.
Hi and welcome to FixYa. I am Kelly. On your cook-top the gas igniters are cycled on and off by a ceramic and copper switch on the front of each of the gas valves. Some of them are in wired Series ...i.e any burner on will cycle all igniters on the cook top and some of them are in Parallel where individual burners are controlled by each gas burner control knob. Inside these tiny ceramic switches there is a flat thin strip of copper that as the gas valve is rotated a cam of the switch actuates pushes the copper strip against the fixed contact. Those little strips over time either break or get bent and stay against the fixed contact. Hence you have and igniter on when the burner control is off. The only fix is to find out which little ceramic switch on the front of the gas valve is stuck. You do it with an Ohm meter POWER off. They all should read open with the burner controls off. The one that reads continuity across the 2 wires is the bad switch.
Thanks for Choosing FixYa.
Kelly
Sep 13, 2010 | GE Cooktops
All cook top burners spark when any is turned on
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
I want to switch my 5 burner kleenmaid CH80x8 natural gas cooking top over to LPG what size jets or injectors do I need. Regards James. Centre burner is for a wok current jets are 50. 78. 85. 62. 95
LPG to natural, natural is bigger than LPG injector exmaple LPG 50=natural 69-
LPG 78=natural 91
LPG 85=natural 115
LPG95=natural 130
PLG 62=natural 85
Sep 09, 2009 | Cooktops
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Mar 14, 2008 | Cooktops
Jenn-Air 35 in. JGC9536 Gas Cooktop Logo
24 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
