Question about Infinity Speakers PS410 Primus 10-Inch 300-Watt Powered Subwoofer
Infinity primus ps410 powered subwoofer makes clicking sound
Why does Infinity TSS-1200 subwoofer make grinding noise?
If it isn't brand new, it sounds like the voice coil is striking. This can be caused by damage to the suspension system or simply an overheated voice coil inside the sub. No easy fix unless your handy at rebuilding speakers. I would suggest buying a new one or sending back under warranty if it is still within warranty period
Aug 11, 2014 | Audio Players & Recorders
My Infinity ps-10 subwoofer makes crackling sounds. I took it to a repair shop and they say it needs a new power supply and a new amplifer and that it will be over $200 to repair it. I only paid $400 (6...
Probably not, but you could make it into a passive subwoofer by disconencting its internal amp and powewring the driver directly by an external amp being fed by an LFE channel.
I did this with a problematic Klipsch SW.
May 14, 2010 | Infinity PS-10 Subwoofer
Where to purchase vertical mounting feet & bolts for Infinity sub
Simple as it sounds, try Home Depot/Lowe's! They will have them! Been there, done that!
Mar 30, 2010 | Infinity BASSLINK Car Subwoofer
No sound coming from my Infinity BU2 subwoofer. Powers up, light comes on, relay clicks, and nothing.
I suspect that whatever semiconductor does all the amplifaction has departed this life. If you check the PC board it might point to a burnt out part or a blown one. If not look at anything big or with a heatsink on it.
Feb 01, 2010 | Infinity BU-2 Speaker
Power lapse/popping sound
The soldering to the wires can go bad. Making the unit turn on and off. The vibrations of the subwoofer over time will cause them to work free. Then when in operation they will cause them to break contact again.
Jul 14, 2017 | Infinity BU-1 Speaker
Infinity ps-10 powers up but no boom
Try hooking up a different signal input to your powered sub, another stereo or even a dvd players audio output to the sub will work for a test. Just make sure the subs gain is down before starting. If it still not producing sound, the subwoofers amplifier is bad. I hope this helps.
Oct 10, 2008 | Infinity PS-10 Subwoofer
PS-12 subwoofer problem - Infinity Customer Support number?
Fixed the problem...I just purchased another one online (from a store that has a good return problem) and will return the one that doesn't work! Cheers! :)
Jun 26, 2008 | Infinity PS-10 Subwoofer
Infinity PS-12 Subwoofer clicking in and out of standby
Unfortunately your subwoofers amplifier circuitry will need to be repaired ,the amplifier is bad and kicking in to protect mode. This mode is designed for safety of the unit and user and sub should not be operated until repaired as it may incur more damage to the components. I hope this helps.
Feb 18, 2008 | Infinity PS-10 Subwoofer
Infinity Speakers PS410 Primus 10-Inch 300-Watt Powered Subwoofer Logo
85 people viewed this question
Top Infinity Speakers Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Infinity Speakers Audio Player and Recorder Expert? Answer questions, earn points and help others
