Question about Dryers
Dehumidifier Hampton bay CFZ160 blinking power light, unit will not go on
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
SOURCE: Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Posted on Apr 15, 2008
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
koolbreezes
  • 540 Answers
SOURCE: I have a Hampton Bay
HEY ,Ive typed in( Hampto bay dehumidifyer) and came up with the parts webpage!
Posted on Sep 09, 2008
  • 26 Answers
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Posted on May 19, 2009
Hampton Bay Window A/C HBQ051A: What is BTU? And, no, obviously it's not posted on the unit, nor do I have any documentation.
First, I'm not a Hampton Bay Tech.
I found this on you tube 6,000 BTU?
*** Following for information only ***
https://www.youtube.com/watch?v=KnNFQGBySlI
https://www.youtube.com/watch?v=7TNy7HpF9zg
https://www.youtube.com/watch?v=XT8BJGvbnZg
* Normally I would suggest checking your warranty but this is a discontinued A/C unit. May not be worth repairing as there are newer units more power and less electrical usage.
Aloha, ukeboy57
Jun 18, 2018 | Hampton Bay Heating & Cooling
Hampton Bay HB30 is not working
its the fan thats not working mayby
May 17, 2014 | Dehumidifiers
I have a Hampton Bay Miramar 60 in ceiling fan, when you try to turn it on the upper light just blinks and nothing else happens. You can't even turn the blinking light off. HELP!!!
Turn off the breaker that controls power to the fan. Remove the batteries from the remote and press the buttons in case one is stuck. Reinstall batteries or new ones. Turn on the fan breaker and try using the remote again
Dec 16, 2012 | Universal Remote Control Hampton Bay...
What does the "dry mode" mean in a Hampton Bay air
"dry mode" normally means, to dehumidify only. this will not cool the air nor heat it consistently.
Jun 19, 2011 | Heating & Cooling
The "dry mode" dehumidifies the air. This is useful when you do not need to cool the air but the relative humidity is higher than you want to have inside. You get the advantage of bringing in the fresh air without increasing the indoor humidity.
I hope this helps.
(this applies to all air conditioners with a dry mode)
Jun 19, 2011 | Hampton Bay HBLG5004 Air Conditioner
I would like to buy a filter for our Hampton Bay dehumidifier. H40 REV-N Serial GN955162 2011
Try this site....
http://www.appliancefactoryparts.com/dehumidifiers/hampton-bay/
Mar 27, 2010 | Kitchen Appliances - Others
I am looking to purchase a used Hampton Bay
This unit you looking to buy only covers 1000sqft .
Mar 17, 2010 | Maytag M7DH45B2A Dehumidifier
There are power surges every few minutes that last for a few seconds. Other lights on the same circuit dim. This is really a Hampton Bay HB40 which I understand is the same unit. What can I do?
it sounds like the compressor is trying to start. if it hums and clicks then either the compressor relay or the compressor is bad. find the compressor and tap on the relay cover with the end of a screw driver. if it starts then change the relay
Dec 03, 2009 | Fedders RDG40 Dehumidifier
Hampton Bay Dehumidifier Model# HB50
MY dehumidifier leaks water from upper part of unit causing water to leak on floor while running.
Feb 23, 2009 | Dehumidifiers
Dryers Logo
63 people viewed this question
Top Dryers Experts
