Question about Click Free Clickfree Hd327 320gb Usb 20 25 External Hard Drive W Automatic Backup
Can't get my hd327 to work on my macbook air - Click Free Clickfree Hd327 320gb Usb 20 25 External Hard Drive W Automatic Backup
I need to have my hacked MacBook Air erased and reinstalled. I need an appointment with a genius in Emeryville/Oakland, CA.
Dial Apple MacBook Air technical support phone number 1-8002044427 for repair MacBook Air & upgrade MacBook Air storage. Troubleshoot MacBook Air Battery, Power and other common problems by Mac help expert Apple MacBook Air Technical Support 1 800 204 4427 Phone Number
Apr 04, 2017 | Apple MacBook Laptop Computer Mac...
Macbook air no power
Are you searching Macbook Air Technical Support Number? We provide world class technical support for Macbook Air and other Apple products with the help of well trained and qualified technicians who are always ready to assist you 24*7 support services. We fix most common issue related to installing and operating system, virus and security and etc.
MacBook Air Technical Support Number 1833 493 0111 MacBook Air Help
Mar 20, 2017 | Apple MacBook Laptop Computer Mac...
Why my Kindle is not working on my Apple macbook air?
Close the Kindle app and restart it. If that does not help, try restarting your MacBook.
If that does not work, try deleting the Kindle and reloading it on your system.
Everything you got from Amazon will still be in your Amazon account.
Oct 07, 2015 | Apple MacBook Air
Macbook Air keeps beeping three short beeps in a loop
I need more info on which model Macbook air you have. You can try to reset the smc and pram https://discussions.apple.com/docs/DOC-3604
but three beeps is often memory related
http://support.apple.com/kb/HT5860?viewlocale=en_US .
Depends on the model you have whether or not the RAM is removable.
Oct 11, 2013 | Apple MacBook Air
My iphoto doesnt work for my Macbook Air, and i can't reinstall it because the MBAs dont have a DVI?
DVI has nothing to do with installing iPhoto. DVI is a video output connection.
Nov 13, 2012 | Apple MacBook Air
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
Mac book air cannot start
When troubleshooting a Macbook Air, there is a checklist from Apple Support you need to try.
You are welcome to do so after first trying these steps first.
• Check the Magsafe power adapter, to make sure it is free of debris and is seated properly.
• If with decent charge, try to start the Macbook Air, with only the battery.
If you get power from either one of these issue resolved- otherwise follow the steps provide more in detail from Apple listed in the link below.
Apple Support Link:
Troubleshooting Macbook Air (additional steps)
Such power issues with Macbook Airs as well as Macbook 13" and Macbook Pro 13" are about the same and there are no workarounds, so make sure to follow those procedures completely for a full assessment of your Macbook Air's functionality.
Hope this helps!
Regards,
-Mactechtrainer
Jan 22, 2010 | Apple MacBook Air
Macbook air internal mic not working
This is a known issue with some of the Macbook Airs - you should bring the machine to an Apple store, or open a case at apple.com
They may be able to repair/replace at no cost, depending on how old the machine is.
Hope this helps, and good luck!
For audio expertise and great AA recordings come over to my website at www.rexark.com
Jan 01, 2010 | Apple MacBook Air
I can't get the mb397g/a working on my apple HELP Pz
Try this procedure with the Macbook Air SuperDrive
and then click the Apple link below to follow the remaining recommended steps with for troubleshooting your Macbook Air SuperDrive.
Here are some steps you can try to resolve the issue:
• Make sure your SuperDrive is connected to your portable.
• Properly shut down your Macbook Air
• Once it is is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Macbook to start up.
Apple Support Link:
Troubleshooting the MacBook Air SuperDrive
This process is supported by Apple, but if it does not work, just let me know.
Regards,
-Terry
Oct 30, 2009 | Apple MB397G/A MacBook Air SuperDrive
Macbook airport tooooo slow
When your MacBook Air is showing some performance issues, it can be caused by either hardware or system problems. If you don't want to pay for hardware upgrade, then try cleaning the system to improve the Macbook speed. Learn more here: http://www.speedupmacbook.com/speed-up-macbook-air.html
Feb 24, 2009 | 2wire HomePortal® 1800HW Router...
Click Free Clickfree Hd327 320gb Usb 20 25 External Hard Drive W Automatic Backup Logo
37 people viewed this question
Top Click Free Computers & Internet Experts
John Hong
John Hong
R Buschy
john cordey
john cordey
Are you a Click Free Computer and Internet Expert? Answer questions, earn points and help others
