Question about Sharp LC46D82U 46 in. LCD HDTV
I have green lines running horizontally from the top of the screen to the bottom. Does anyone know what might be causing this
  • 208 Answers
SOURCE: Green line
Sorry, 9 times out of 10 this is a defective LCD Panel....Call Sharp customer service and the may extend your warranty.
Posted on Feb 05, 2008
SOURCE: Horizontal green line appears on screen
my maxent plasma tv has the same problem but it has green and red lines. I found out that hitting the tv from the back works. It used to last a long time but now i have to get up now and then to slap the tv on back with my hands! anyone with a long term solution?
Posted on Jun 12, 2008
  • 80 Answers
SOURCE: HORIZONTAL LINE THROUGH PICTURE
Defective LCD panel. I hope it is under warranty, otherwise you'll have to live with it or buy a new set, as the LCD panel costs almost as much as the TV itself.
Posted on May 21, 2009
SOURCE: emerson 32 inch lcd tv two years old has lines
I don't know anything of this particular TV, but what you describe is generally a known problem in LCD displays.
it's caused by one of two things - either parts of the LCD film thin film for the vertical lines detatching from the board it is glued on or certain micro controllers that are also glued on the LCD film starting to get burned bit by bit. In both cases, the whole vertical line responsible for one of the three colors that a single pixel consist off get dead and depending on how they get dead they get either all open or all closed, respectively completely turning on or shutting off the particular color.
It is most commonly the first case, but whichever of the two it is, there's no known cure for it within reasonable cost.
I've experimented a few times and was able to press the film to the board by using firm objects and fastening the display case, but it would often cause more harm than it brings and even more often it would just not hold reliably. Overall I do not recommend experimenting with it it unless you have lots of time on your hands and you're ready to face an evern worse damage.
In a very rare cases it might also be the tcon also known as LCD controller...but from what you describe it's hardly it. It's worth trying, but if I had to take a guess I'd rather rule it out - it sounds like the LCD.
And the bottom line is you just have to face it - you likely need a new TV. If there's some chance for me to be wrong, try the tcon board at the back first. Then just sold the TV on eBay or CL for whoever gives you most and apply the money towards the new purchase.
Don't kill me, I'm just the messenger :-)
Posted on Nov 09, 2009
SOURCE: the horizontal on the screen has moved i have a 2
i have same problem it happens with my hdmi and component port.
did you ever find out what the problem was?
Posted on Feb 16, 2011
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Horizontal line on screen sometimes
Generally horizontal lines are caused by the panel failing, you can try a new tcon but I don't think it will help.
Mar 01, 2018 | Philips FTR9955-17 DTV Receiver
Green hazy lines across my projection tv screen
The coolant in between the CRT face and the focus lens has probably become discolored and would need to be drained, cleaned and refilled. The green CRT is the center one and it would have to be romoved in order to refill it.
Sep 20, 2009 | Philips 51PW9363 51" Rear Projection...
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Sanyo Bravo
check if its on all the video sources. check it on dvd if its there then contact the customer care
Jan 07, 2009 | Sanyo DP32746 32 in. LCD Television
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Sharp LC46D82U 46 in. LCD HDTV Logo
46 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
