Question about Whirlpool GGW9250PL Gas Dryer
Natural gas to propane
My dryer is set up for natural gas and I need to change it over to propane. How do I do it?
  • 1 more comment
  • Gleason Sep 27, 2007
    who do I get to do this change over?
    I am handy? where do I find the parts ?
  • Gleason Sep 28, 2007
    Thanks very much for your help that has helped me a great deal.
  • 640 Answers
The pilot and/or burner orfices need to be changed.depending on your model the gas valve may also need to be converted.
Posted on Sep 27, 2007
  • anthony james
    anthony james Sep 27, 2007
    a local plumber could do it and if your handy you could.
  • anthony james
    anthony james Sep 28, 2007
    go to any appliance repair center that sells and services appliances,they can find the parts for you.
SOURCE:
Can I change a propane dryer over to natural gas it is a maytag md 3500
yes you can, you need a LP kit but it can be done. Go to the local appliance store and they can help you.
Mar 14, 2015 | Maytag Dryers
I'm converting my natural gas dryer over to LP gas. I've changed the orifice but it is saying to close the regulator. It says the same thing with Natural gas but that doesn't make sense because it isn't...
I know from working on piles of restaurant equipment, that when you change over from natural to propane, you have to change the orifices and the regulator. Most natural gas equipment needs 3.5-4.0" of W.C. (that is, water column) and most propane gas equipment needs 9.0-11.0" W.C. The density and specific gravity of the gases are different. If it is glued so as you can not make any adjustments to the pressure, change the regulator to a propane one. Most natural gas regulators can not be adjusted to the propane pressure needed. Please be careful as working with gas can be dangerous. Natural gas is usually lighter than air and will rise but propane is heavier and will "pool" or "puddle" in low areas and can cause explosions in the right circumstances.
Dec 05, 2017 | Kenmore Dryers
I have a lg dryer DLG5988S is it natural gas or lp?
most of these dryers are factory set for natural gas and need to be converted to propane if using propane
Feb 09, 2011 | Dryers
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Amana NDG2335AWW Gas dryer LP or Natural?
If there are no stickers indicating so, you will need to open up the dryer and measure the gas orifice. A propane orifice should be either a #54 or #58.
Jan 13, 2010 | Amana NDG7800AW Gas Dryer
I have a Whirlpool gas dryer. I have gone from a natural gas hook-up to propane. Is there anything I need to do different for that natural gas installation?
You will need to change the gas discharge jets on the burner so that the burner gets the proper mixture of gas and air. Propane accessory stores should be able to furnish a conversion kit.
Aug 21, 2009 | Dryers
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Jun 08, 2009 | Whirlpool GGX9868J Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
197 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
