Question about Frigidaire GLTF2940ES Front Load Washer
Ftfb4000gs1 what washer can fit with a frigidaire dryer serial# xd80905996 my washer is broken and its stack on top of each other
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Posted on Nov 16, 2007
  • 156 Answers
SOURCE: Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Posted on Mar 06, 2008
  • 23 Answers
SOURCE: Removing the agitator
Pull the top of the agitator off...there is a nut inside of it (ratchet and socket usually 5/8 and a long extension) pull agitator out.
Posted on Nov 04, 2008
SOURCE: Dryer buzzer is SO LOUD - How can I adjust volume/turn off?
Buzzer mounted to back of control panel.
**UNPLUG POWER BEFORE REMOVING CONTROL PANEL OR TOUCHING -ANYTHING-!**
Located on left side of control panel, bolted to back. Small rectangular device with two connections and no associated button or dial.
Remove the panel and disconnect one of the leads. Fold the connector back against its wire, carefully and securely tape the connector with electrical tape so it cannot touch anything. Also tape the connector on the buzzer that you removed the wire from.
Re-assemble the control panel.
As with anything mechanical, hours of frustration trying to take something apart can be avoided by taking a few minutes at the beginning to look closely at how it is assembled.
Posted on Aug 08, 2009
marka19
  • 1430 Answers
SOURCE: Frigidaire FEX831CS Top Load Stacked Washer won't
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Jun 03, 2010
Im having a problem with my washer it won't work and its flashing loc
Good Afternoon Jesslyn, I am happy to assist you!
I understand your washer is not working and flashing LOC; however, I see that your question is listed under Frigidaire FEX831CS (Top Load Stacked Washer/Dryer). This specific laundry center does not have a digital display. May I please have your model number? You can typically locate the serial tag, on the upper front as you open the door.
In the meantime, if you have a front load washer, I suggest pressing OPTIONS and SELECT at the same time and hold for approximately 15 seconds until "LOC" is no longer displayed. I hope this helps!
Thank you - Z.
Apr 05, 2014 | Frigidaire FEX831CS Top Load Stacked...
I have a Frigidaire GLET1031 Top Load Stacked Washer / Dryer. The water valves do not work unless the dryer is turned on. Also the washer drum will not spin with dryer on or off and the dryer does not get...
WHat ya need to check is for proper power going to the entire unit it sounds as if either a breaker is off or their is burnt/broken wire from the main power connection.
All symptons listed i suppose occured suddendly?? and to me its a lack of proper electrical power that is causing all of them.
GENE
Oct 03, 2011 | Frigidaire GLET1031 Top Load Stacked...
My Frigidaire front load stacked washer/dryer makes a horrible noise and won't spin. It works perfectly except for the spin cycle
you need to remove the agitator take the cap off and remove the bolt from inside the agitator and then remove it look at the metal trunion in the bottom of the tub and see if there is a broken bolt holding the trunion to the shaft.there is a chance the transmission need to be replace if there is no broken bolt
Nov 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
I have a top load stacked washer/dryer. my washer is out of balance and the tub is lose also starting to make a seaking noise.
you need to remove the agitator and look at the bolts that hold the tub to the shaft it sounds like you have one broken or loose.there is a slot on the sied of the shaft that the braket fits in and gets tightend to make sure it is seated properly.
Feb 12, 2010 | Frigidaire FEX831CS Top Load Stacked...
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire GLET1041AS1
Unplug unit! Remove top screws and pull off top lid of dryer. Heater terminals should be at top right. Use ohm meter to check resistance. If ohms won't display, then your heater unit probably has an open circuit. For instance, my GLET1031 has a reading of 12.5 ohms.
Sep 30, 2008 | Frigidaire GLET1031 Top Load Stacked...
How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Apr 08, 2008 | Frigidaire GLGQ642A Gas Dryer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Frigidaire GLTF2940ES Front Load Washer Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
