Question about Saws
I have an old rockwell 314 type trim saw in great shape. Someone else has a question posted and you have it under band saws which it is not. I have the same question what oil is used for the worm drive and how do I find parts for this sucker? It is a great quality saw and a new line is $400 bucks no thanks! Portercable took over years ago and the current 314 trim saw is nearly identical except the brushes are larger so I am sure the motor is much different.
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 14 Answers
SOURCE: wood like to clean &
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Posted on Jan 18, 2009
  • 360 Answers
SOURCE: band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Posted on Mar 31, 2009
efs_perpends
  • 1996 Answers
SOURCE: manual or info on a rockwell 28380 14" band saw
I can't find one for the exact model number you have, but there are a lot of manuals for the same era bandsaws available as PDF downloads at this site. Perhaps another manual for a similar machine will help answer most of your questions, in lieu of the correct one...
Have a look around there, though, at both the Delta and Rockwell listings, as I just made a quick look to find yours and there might be something there somewhere.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 15, 2009
  • 178 Answers
SOURCE: I need the part number
Hi Dwayne, your Motor can be purchased from Sears at this link:
http://www.searspartsdirect.com/partsdirect/part-number/816613/0009/113&pathTaken=partSearch&blt=14&prst=0
Just by looking at the date code, I would imagine 1987, 3rd week
I hope this helps.
Posted on Dec 08, 2010
How much does a rockwell 14" band saw cost?
It has been discontinued by Delta. It would be hard to find replacement parts for this band saw. I think Rockwell 28-20C would cost $100-200.
Aug 02, 2014 | Delta Woodworking Delta Rockwell 14 Inch...
Where do I find a guide rail for a Rockwell 4500 circular saw?
If I'm not mistaken, that model saw is already discontinued. I suggest you call or email Tool Parts Direct or Delta. I only have band saw machine, I'm thankful that bandsawparts.com makes aftermarket parts for all brands of band saw.
Jul 17, 2014 | Delta Woodworking Delta Rockwell 14 Inch...
Rockwell/Delta 20" bandsaw. Locked
This site has the best collection of online manuals for older Delta machines. Have a look through the list and see if you can't find one of similar vintage. Hint; if you click on the pub type heading the list will sort by machine type. Also confirm that model number is correct. There are manuals for the 28-340 that may provide the needed information. I'm afraid I'm not familiar enough with that saw to suggest a solution to the low/high speed issue.If you are running on the correct pulley positions, and they pulleys are corectly aligned, the belt tension adjusted, and the motor in good shape, I don't understand what the obstruction could be. Perhaps you neglected to adjust the belt tension when changing positions? See the guide suggested above for more on that.
Jul 28, 2011 | Delta 28 640 20" Single Phase Wood Cutting...
Need service and repair manual for rockwell ban saw #28-243 model 14
Please check the publication reprints available from this website, in particular this link.
They are owner's manuals rather than service manuals, but include exploded parts views and lists and most required instructions.
Good luck.
Jul 20, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
Rubber on wheels is shot. Where can I get new rubber?
Here are a few links to new tires for your bandsaw, available here and here and here. If you google "bandsaw tires", you'll find they are pretty widely available and may be able to come up with a better price...
May 08, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Manual or info on a rockwell 28380 14" band saw
Apr 05, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Manual & fence system
I would contact the nearest Rockler woodworking store. they have or can get it for you.
please mark this as a fixya!
Mar 12, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Saws Logo
29 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
