Question about GPS
Can't display time on front of device - GPS
    New Friend:
I told him all that happened between me and my wife and he told me that his going to help me out i never believe that he is going to be true i thought that it will not work.. but to my surprise it work for good for me.email or call him at drumahonsolutiontemple2@gmail.com and +2348067148308
Posted on Oct 21, 2013
How do I reset the time on Garmin vivofit
You should synchronize your device to receive the correct time when you change time zones, and to update for daylight saving time.
  1. Confirm that your computer or mobile device displays the correct local time.
  2. Select an option: Synchronize your device to a computer (Sending Data to Your Computer).
v?vofit Owner's Manual - My device does not display the correct time
https://www8.garmin.com/.../vivofit/.../GUID-FF71ED02-BAE2-4992-BF85-661A5BF0
Nov 07, 2016 | Garmin GPS
Harman kardon Avr 254 fix. No video trying to find out which time delay fuses to bypass. Does anyone have a picture. Lost all video and front display locked up except for volume and radio
I never recommend running video through any receiver. It's best to connect your playback or broadcast devices directly to your monitor.
Jan 01, 2015 | Audio Players & Recorders
Machine is saying Printer Jam Offline
Open the front cover and gently pull the paper towards the front of the device. Close the cover and press the "Stop/Exit" button.
If you still receive the message then perform a reset.
You need to keep pressing the DOWN or UP to keys a couple of times until you see 'Maintenance 99' displayed on the display. Hold down the 'Set' button to go to stand by mode. Please note that if you press the exit key only after typing in a single digit the machine goes to maintenance mode in initial stages.
Hope this helps.
Shane
Feb 08, 2011 | Brother FAX 8350P Laser Printer
No time showing on the screen
Select the system settings from the main menu, then you select the time format, set the time to the proper time, there is an option to display the time from the settings. Once you select the display time it will display time on the home screen of the device.
Hope this helped. Thank you for using fixya.
Jan 20, 2011 | Magellan RoadMate 1424 GPS Receiver
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
How do I set my Woods N1506 timer?
According to another fixya answer posted December 4 2009:
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Nov 23, 2010 | Woods Outdoor Lighting Timer
I need instructions for using my N1506 timer.
Plug in timer – The letter C will Flash
Press Time Button – It will advance to 1 a.m.
Press Mode button – Letter P will flash inviting you to set the program
Press Mode button again – the letter E now flashes.
Press time button – Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
FOR MANUAL OVERRIDE
Dec 04, 2009 | Woods Hardware & Accessories
How to change time in Tomtom GPS device
Here's the solution to your problem:
> Tap the "Change preferences" icon
> Tap the Arrow Icon until you reach the screen with the "Set Clock" Icon
> Tap how you would like the time displayed
> Tap done
> Set the correct time to display
> Tap Done
This will set the new time on your unit.
Mar 13, 2008 | Tomtom ONE GPS Receiver
GPS Logo
16 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
