Reset lg dvd recorder - Televison & Video
The recorded picture is very blurred
I had the same problem on my LG rht599h dvd recorder, I had set the record mode to SP but it would switch itself to MLP mode which was very blurry, Why there is a MLP mode anyway I cannot understand because the quality is terrible. To rectify the problem go to setup and reset to factory setting and that will stop it from switching once you set to the mode of your choice.
Feb 18, 2013 | LG RHT599H 500GB HDD DVD Recorder with...
Recorder dispaly
Hello
Make a factory reset to this device. Refer its user manual for proceedings.
Mar 07, 2012 | LG RH1999H DVD Recorder/HDD Recorder
Returns error message :Unknown Disc. Please Check Disc Again" The DVD disc plays on other DVD players with no problem.
Problem may be reset needed, or lens need cleaning, or dvd recoreder worn out. Reset is pull the plug from the wall for 5 minutes. Turn it back on after reset to load firmware again, may work after that.. TDK makes lens cleaner. LG uses fan so, dirt can get into dvd recorder lens. If the tray moves out wiggly, laser assembly may move wiggly too. Replace dvd recorder which is a dvd+-rw regular ide unit from computers.
Aug 20, 2010 | LG RC-197 DVD Recorder/VCR
My LG RH265 keeps opening the tray. When I close it with the remote, it opens itself again. This problem repeats itself on and on. What can I do about this, is there a way to reset the recorder?
My RH265 has had this fault three times and on each occasion LG have replaced the 815V DVD Deck (Part No. EAZ34934813) - This fault seems to be common to all their recorders and in my view gives LG an otherwise undeserved very bad name for product reliability. I am very surprised that they do not appear to have solved the problem with a reliable component.
Dec 06, 2009 | LG RH177 DVD Recorder/HDD Recorder
Lg dvd recorder
No, this is a fault with the unit, 99% of the time caused by the power supply, but I've seen it be caused by the MPEG pcb
Apr 21, 2009 | LG DR-4810 DVD Recorder
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
DVD locked in and door is not opened
might have stuck inside...u got to open up the system onlly
Apr 01, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG rh7624w
Call their tech support. The # is on the DVD.
Oct 29, 2007 | LG DR197 DVD Player/HDD Recorder
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
