Dgaa070bdtb combustion switch
Already replace pressure switch do I need a. Booster assembly motor
3 Suggested Answers
  • 102 Answers
SOURCE: I replaced the combustion inducer
Could be. what is the voltage going to the inducer? You might have a bad ground or a polarity problem. Let me know what voltage you have and we will go from there. Does the main blower motor run fine?
Posted on Dec 30, 2010
  • 1033 Answers
SOURCE: combustion air switch failed to close---Model#
Hello, a pressure switch fails to close for a few differant reasons, 1) there is a obstruction in the flue pipe or chimney, 2) the small hose that goes from switch to inducer is either loose, obstructed, or sometimes condensation can build up in that small hose 3) the switch itself is bad and must be replaced. Theses are a few reasons why it wont close. If you are getting 24 volts to the switch than the control board is good. however if you are not getting 24 volts to the switch than you are correct and the board must be replaced.
Posted on Feb 08, 2011
1988 lincoln mark vii abs light stays on and hard breaks
The ABS unit has failed and needs to be replaced.
May 13, 2014 | 1988 Lincoln Mark VII
I have hard breaks on my 1988 lincoln mark vii and my abs light stays on any help
Bad vacuum brake booster test booster by shutting car off and don not touch pedal open hood and remove hose to booster a wooosh sound should be heard if not need a booster.
Furnace kicks out every so often, ran for two days this time, then kicked out on a pressure switch open, i have replaced the combustion motor ,pressure hose ,and pressure switch, runs for a while then...
You are going to need a service man. A magnehelic gauge is needed to properly diagnose a pressure switch issue. Could be a blocked or restricted flue, a defective induced draft motor, cracked heat exchanger, restricted secondary heat exchanger, ect. ect.
Feb 21, 2014 | Intertherm 56000 Btu Gas Furnace
What does a pressure switch look like ?
Generally above the burner assembly, there is the combustion fan motor and tied to this is a rubber hose. The rubber hose will lead you to the pressure switch. (It has 2 wires on it)
Dec 15, 2013 | Carrier 3 Ton 13 Seer Commercial Gas Pack...
WHY ARE BRAKES SO HARD TO PRESS ON 90 LINCOLN MARK VII?
The power brakes vacuum booster... may have a vacuum leak. you can check it with an engine vacuum meter, or remove the rubber hose from the booster and plug it.. and see if the engine changes pase, idle smooths out, revs a bit higher, etc. noticeable change in engine idle would confirm a leak.
Oct 01, 2012 | 1990 Lincoln Mark VII
Hyraulic brake pump is bad i need a replacement
Are you sure the hydraulic motor is bad?....as it's usually a problem with a relay and/or the pressure switch.
LEARNING ABOUT THE "TEVES" BRAKE SYSTEM
The hydraulic brake booster on a late model Mark VII and early Continental is very different from most. It is equipped with something known as a "TEVES" brake system.
The main parts in the system that we will discuss include an ACCUMULATOR, a HYDRAULIC PUMP, a hydraulic pump RELAY, and a PRESSURE SWITCH. These are the key players in this operation.
THE LOCATION OF THESE PARTS ARE AS FOLLOWS:
HYDRAULIC PUMP MOTOR= Underneath the brake assembly (2 pin connector) Hydraulic pump motor
RELAY = On the drivers side strut tower
PRESSURE SWITCH = 5 pin connector facing the # 7 or 8 spark plug(drivers side)
ACCUMULATOR = Round black ball on the drivers side
WHAT THESE ITEMS DO:
HYDRAULIC PUMP MOTOR is an electric hydraulic pump used to "boost" pressure for the brake assembly. This pump is $900 new!
hydraulic pump motor RELAY is just what its sounds like. It gives the hydraulic pump motor power to come on.
PRESSURE SWITCH is the "brains" in the system. It senses how much pressure is "on line", and when the system needs more pressure, it tells the relay to "power up" the hydraulic pump motor.
Another one of its jobs is to turn on the RED BRAKE LIGHT, then the ANTI-LOCK lights to alert the driver that the pressure is dangerously low. (The reason the anti-lock light comes on, is because the ABS cannot function if there's a problem with the manual brakes)
ACCUMULATOR stores energy or pressure like a reservoir. Its there so the hydraulic pump motor only has to come on every 3rd or 5th time. Its design is more complicated, but basically the same principle as an air tank on a compressor.
WHAT NORMALLY HAPPENS:
What usually happens is, in time, the accumulator gets weak with age and can't hold the pressure like it was designed too, and therefore, the hydraulic motor comes on every time the brakes are applied....rather than every 3rd or 5th time. This means all these parts are working 3 or 5 times more than they were designed to. This puts an extreme amount of pressure on an already old system.
What we know from this is, the accumulator needs replacing because it's what started all this, but now the pressure switch and relay needs replacement also because it has worked overworked.
NOTE: always replace the relay when replacing the pressure switch. The relay came on every time the pressure switch told it too, so if one is worn out....the others not far behind!
Sep 09, 2012 | 1990 Lincoln Mark VII
When antilock brake and brake lights are on and pedal is hard to push and stop.What is typical on a 1990 lincoln mark seven
The hydraulic brake booster on a late model Mark VII and early Continental, is very different from most. It is equipped with something known as a "TEVES" brake system. I'll attempt to teach you what does what and why, so you won't spend a ton of money just because you and maybe your mechanic aren't familiar how it works. The way it's always been is,..."if you don't understand it...replace the whole thing"! The problem with using this technique is, unless you want to spend $2K for the whole thing, your going to be buying a used system....which may not be a whole lot better than the one you have now.
Another one of its jobs is to turn on the RED BRAKE LIGHT, then the ANTI-LOCK lights to alert the driver that the pressure is dangerously low. (The reason the anti-lock light comes on, is because the ABS cannot fuction if theres a problem with the manual brakes)
ACCUMULATOR stores energy or pressure like a reservoir. Its there so the hydraulic pump motor only has to come on every 3rd or 5th time. Its design is more complicated, but basicaly the same principle as an air tank on a compressor.
Jun 08, 2011 | 1990 Lincoln Mark VII
Combustion air switch failed to close---Model# DGAA070BDTB--heater works sometime and sometimes not--believe bad circuit board
Feb 08, 2011 | Coleman Heating & Cooling
Evcon, 3 flashes, combustion air switrch failed to
I have 2 of these furnaces in mobile homes I own. On both of these the wheel inside the draft inducer blower that has the clear tube attached to it has a small wheel in it that over time tends to stick. Take the 4 screws out and give this little wheel located towards the bottom a push. Your problem may be solved without investing in expensive parts :)
Jan 26, 2010 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
