Question about Philips 42PF9630A 42 in. Plasma Television
Philips 42 inch Plasma television
My daughter turned my television on last week and we had lines accross the screen. Actually it looks like rectangular boxes of lines that go 3/4 of the way down the screen. it sort of --------------- looks like this: --------------- A basketweave of *************** distortion. *************** Its not so bad when --------------- the picture is light --------------- but dark pictures *************** show the distortion ***************
  • 1 more comment
  • Anonymous Nov 01, 2007
    One day the TV was fine, the next day I turned it on to discover a series of colored vertical lines going across my screen. It seem to "coordinate" w/the image on the screen. The lines are about 1/4 inch apart. I tried installing the latest software updates--no change. I unplugged it for 24hrs--no change. Philips won't help since my set it over a year old (18 months actually). Having a hard time getting someone to the house to look at it. I don't think they know any more about it than I do! I've ordered something called Pixel Protection from the UK. It's a DVD that helps fix "dead" pixels or screen burn. I figured it was worth a try. When it arrives, I'll tell you if it worked. Don't let someone tell you the gas needs recharging--it's a LIE!
  • bmich63 Jun 03, 2008
    Out TV has a series of black lines, then grey lines then black lines across the TV on the upper 12 inches of the screen. Could this be due to a lightning strike, or is it another problem. It just started this evening. I would be happy to send a picture if you give me an e-mail address. It is about 17 months old and out of warranty.
    Thanks. Beth [email protected]
  • James Peters
    James Peters May 11, 2010
    could u include a picture of the problem so i can see what your talking about and see the problem for myself ?
  • 138 Answers
I habve seen this issue with this sets and if the vertical lines are in the menu as well and there are more than one line the panel would need to be replace. Contact a tech in your area to see if then can put the set in white screen mode and leave it there for a couple of hours and see if the lines go away. If not then the set would need a panel.
Posted on Aug 20, 2008
SOURCE:
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Mar 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
I have 16 horizontal lines about 7 inches from the bottom of the screen. They are about 1/16 inch wide.
Are the lines visible on every xhannel or do they move and appear and diappear with channel changing? are the lines black?
Feb 16, 2010 | Philips 42PF9630A 42 in. Plasma Television
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
My phillips 42 inch plasma tv just clicks when I
There is no lamp in a Plasma TV screen and no ballast.
Check the power supply capacitors.
Aug 19, 2017 | Philips 42PFP5332D 42 in. Plasma...
We have a panasonic 42 inch plasma, less than 3 weeks old. When connected to our play station or dvd player, there is a white line at the top left of screen, only half way accross then stops. Tried...
Try changing the video output mode of the playstation and dvd player from CVBS (often called composite or video) to RGB. this should sort the problem.
Oct 06, 2009 | Panasonic Televison & Video
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Philips 42PF9630A 42 in. Plasma Television Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
