Question about Century Portable Plasma Cutter 82021
Who makes c3entury welders - Century Portable Plasma Cutter 82021
  • 407 Answers
These machines are made by Lincoln Electric commercial division.
Posted on Dec 03, 2015
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
Can low oil cause welder not to perform
The oil is used as a cooling system, therefore if you ran a machinery without expect to overheat, dismantle your welder and check which parts have melted, repare or replace them and make sure there is enough oil at all time
Jun 08, 2014 | Miller Trailblazer 302 Welder Generator...
Welder when turn on trips the breaker
Would you write back and clarify what steps you have taken to narrow down your search? I'd like to know if the breaker is weak and needs to be replaced. Have you plugged your welder into another receptacle to see if it trips that breaker? I don't think the trigger has to do with this problem. The symptom is that as soon as you turn the welder on, it then trips the breaker. So this tells me that the electrical cord is not shorted. When the breaker trips, is there any delay or is it instant? If there is a delay, does it sound like it does while you are welding? Do you hear that "Transformer, buzzing noise"? The trigger activates the feed motor, that alone isn't enough to trip this breaker. Which make and size welder do you have? I really am dependent on detailed information, you are my eyes and ears. Please write back with any questions or new details and I'll do my best to help, good luck.
Mar 15, 2014 | Welding Tools
Mig welder model# 205680 make a rare noise when turn on
Take the wire out of the hose to the gun and see if noise stops. You may have a short in the Trigger
Nov 16, 2013 | Craftsman 304 FI 95 Amp 120V Flux Core...
My lincon welder sa 250 won;t turn on after i turn it off
Lincoln's welders have a very weak on/off switch sometimes you need to wiggle the switch a little bit to help make contact. Try this, open the welders cover and using an insulated tool and insulated gloves try to bridge the switch. If the machine makes contact then buy a new on/off switch and change it.Other tip is to check your cable plug to see if all cables are still in place.
Nov 10, 2011 | Welding Tools
My snap on welder isn't working properly. With the heat dial turned all the way up, I have to turn the wire speed almost all the way down. Even with it in the hottest setting it welds cold. Won't even burn...
I own and love my Snap-On YA-212A and had a similar problem that turned out to be a power issue, not a welder issue. Repair costs and parts availability of these welders can vary wildly, it may be cheaper to replace it with a Lincoln, Miller, or Hobart. Snap-On uses more than one supplier to make their welders, if you tell me the exact model number I can probably tell you who manufactured it,
For now, try the following:
  1. Unplug the welder from the power outlet on the wall
  2. The power cable where it connects to the welder should be a twist lock type, make sure it is not loose. Take it off and look for any signs of arcing that look like it may have been a bad connection
  3. Look at the power connector that plugs into the wall and look for signs of arcing. If possible, take the back off the plug that goes into the wall and ensure that everything looks tight.
  4. Put the power cable back on the welder
  5. If your breaker box has a load controller turn it off and try your welder again
  6. Replace the circuit breaker in the breaker box on your house
Feb 26, 2011 | Snap-On Welding Tools
I have a craftman mig 110v mig welder arc problem
Check to make sure the contact is not touching the nozzle of the mig welder. This would definitely short it out!
Apr 14, 2010 | Lincoln Welding Tools
I have a speedline 180 amp arc welder and it doesn't want to arc i turn welder on it makes the nose its spose to make and i connect my earth go to strike and nothing happens? any ideas??
Check for output voltage (ac or DC depending on model).No voltage,welder has a problem.
You must have a clean ground clamp attached to bare metal with some welders to make them work.
Sep 08, 2009 | ARC Welding Tools
Century Portable Plasma Cutter 82021 Logo
598 people viewed this question
Top Century Welding Tools Experts
Bill Boyd
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
