Question about Microsoft Xbox Console
Xbox wont recognize any Xbox game disc
The box boots and i get the selection list for music, network play, etc but not games. I put in halo or other games that formerly played and a screen pops up saying it does not recognize this as an Xbox disc. Can you help?
That happened to my xbox console I replaced the dvd player on the console on the xbox
Posted on Oct 06, 2007
Let the xbox run for a certain amount of time. this same thing happend with me. Or just hit the thing until it plays. But be careful ive got the red light coming on now.
Posted on Oct 02, 2007
Replace the dvd player. on the console
Posted on Sep 27, 2007
Wht does it mean when you put a xbox 360 gme in the console and it says play dvd and sometimesa wont read the game discs
When it says play dvd, it just randomly doesn't recognize that it's a game. Press A and you'll enter the game.
When it doesn't recognize the disc all together, I'd suggest cleaning the disc with an anti-static cloth then putting the disc back in.
Mar 05, 2011 | Microsoft Xbox 360 Console
I recetly got my x box 360 flashed with 1.61 iextreme and now it plays original x box 360 games fine but the backed up discs it comes with unreadable disc error and noisy grind and after number of attempts...
Hi
If you have flashed your xbox 360 with 1.61 firmware, have you got the Wave 4 patch disc, lot of currently released games need this disc to be run first before you run the copied games,you can check on google for the updated list of Wave 4 copy protection enabled games.
If you face problem with all copied game discs, even for older ones like Gears of War 2, Halo 3 etc then you should get the drive checked with the person from whom you have got your Xbox 360 modded
Jan 25, 2010 | Microsoft Xbox 360 Console
Xbox 360 will only read halo !!
That is an odd problem. It sounds like you maay need to change the laser or the dvd rom assembly if its reading only one game, yet all the games it wont read are working ok in another console. If i was you id simply replace the DVD rom drive, making sure its the same version as the original from the unit. I hope this helps. Good luck.
Dec 05, 2009 | Microsoft Video Game Consoles & Games
Any game i play disk arcade or demos xbox freezes
Try the following:
  1. Hold disc by the edges without touching the surface with your fingers. Clean the disc with a soft cloth, lightly wiping from the center outwards. Do not use solvents or chemicals to clean the disc. Examine the disc for any visible signs of damage.
  2. Verify whether the Xbox console clock is set correctly.
    • Turn on the Xbox console without a disc in the drive.
    • Press the directional pad up or down to select Main Menu, and then press A.
    • Press the directional pad up or down to select Settings, and then press A.
    • Press the directional pad up or down to select Clock, and then press A.
    You can see the date and time from this screen. Correct the date and time as neccessary.
  3. Try to play the game again. If this does not work, you can try to clear the game cache on the Xbox hard disk. If you have a Xbox Memory Unit available, copy the game cache for this game from the Xbox hard disk to a memory unit:
    1. Insert a memory unit into a controller connected to your Xbox console.
    2. Open the disc tray and remove any disc, if present.
    3. Close the disc tray and re-start your Xbox console.
    4. Select Memory from the main Xbox Dashboard, and then press the A button.
    5. Select Xbox Hard Disk, and then press the A button.
    6. Locate and select the game you want to back up in the list of games.
    7. Select the appropriate save game icon. The Save game icons are located to the right of the game icon. Each save game is identified with a name, date, time, and size.
    8. Press the A button to display the Copy/Delete menu for the save game.
      Note: If Copy is not available, you have not chosen a save game file.
    9. Select Save, and then press the A button.
    10. Press the A button again to save to the appropriate memory unit.
    11. As soon as the copy is complete, press the B button to return to the list of save games.
    12. Repeat these steps as needed to back up your other saved games for this game.
    If you do not have a memory unit, deleting the game cache removes your progress in the game, high scores, and other information. To find the game cache, follow these steps:
    1. Open the disc tray and remove the any disk, if present.
    2. Close the disc tray and re-start your Xbox console.
    3. Select the Memory option from the Dashboard.
    4. Select the Xbox Hard Disk.
    5. Locate and select the game in the list of games.
  4. Select the large game icon to the left of the list and press the A button.
  5. Press the Abutton again to delete the game cache file.
    Note: Delete should be the only available option. If Copy is available, you have chosen a game save file and not the game cache file. Press the B button to return to the list, and then select the leftmost icon.
  6. Select Yes to permanently delete the game cache, and then press the A button.
  7. Confirm that the icon is no longer listed, and then re-start your Xbox console.
  8. Insert the game disc, and then either load your latest saved game from the memory unit, or play the game from the beginning.
Sep 19, 2009 | Microsoft Xbox 360 Console
Hwhat does it mean when it wont read one game but will read another
it means the one that wont read is scratched, dirty or defective, my advice is to clean it if its dirty, get a cd repair kit if its scratched or take it back if its defective.
Sep 13, 2009 | Microsoft Xbox 360 Console
Wont read disc,instead says open tray
Try turning the xbox on and off. Try removing the power from the xbox and plugging it back in. Try other discs and see if it works. Try doing updates on your xbox360 and see if that fixes the problem. That fixed mine with Halo.
Aug 07, 2009 | Microsoft Xbox 360 Pro System Console
Halo 3 not showing text or music.
try going to your xbox system settings and press A, then click on your memory Icon and when you see a selection that says Storage Devices and in that area you see your hard drive, on the bottom there is a button that says device options. click on the device options by pressing Y and then press in this exact order Y,X,X, LB, RB, X, X. The xbox will then ask you if you would like to perform maintenance on you Xbox 360. Click on Yes and it will perform a check and service on your hard drive. I do not know exactly what it will check but I do know that it will cause the system to have to redo the updates for each game. This might help by clearing problems that an update may have had. And it will reinstall the updates as you put the games back in. No harm to your system nor the warrenty.
May 20, 2009 | Microsoft Halo 3 for Xbox 360
Halo 3 prob wont let me go past level 4 says disc error
you can try installing the game onto your hard drive and then playing it, or try to get a new copy of the game. the xbox number is 1-800-4MY-XBOX
the only way i know to clear the hdd is to do it manualy from the dashboard.
Jan 14, 2009 | Microsoft Xbox 360 Console
Need help
Only certain Xbox games such as Halo 1 and 2 will play on the Xbox 360, there is a full list on microsft's website somewhere. to play these games your Xbox has to have a hard drive, and it must be on this list.
Sorry to be bearer of bad news if your fav Xbox game wont play, it happened to me when i got the 360
Mick
Please rate if helpful
Nov 18, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
94 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
