Question about Moultrie Game Spy I-45 Ir Game Camera Mfh-dgs-i45
Didital screen displays CMPO VER.83.18.40 Will not let me do anything, aim light stays on all the time
IXY didital 10 isnot showing display
You need to quit posting same question over and over.
Jan 26, 2013 | Cameras
Display does not show at all when booting up.... Is threre s keyshorcut that might have been pressed
I've found out if you close the screen enough to barely press the power button after powers on then its ok to open it up all the way
Nov 17, 2010 | Dell Inspiron 1000 Notebook
Sanyo vpc-s120 12.1 megapixel digital camera the lcd screen has a dot on it. can anyone help me!!
Seems to be a common problem... walmart.com reviews show a few people having the same problem and after only owning this camera for 3 weeks, it is doing the same thing to me. I'm taking mine back for a refund tomorrow.
Aug 15, 2010 | Sanyo Cameras
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
When I load the AIM function on my matrix, it freezes at the ATT and AIM version: 4.6.22 It signs me in but i can't look at anything. it just stays on the screen. and when I close it, the online symbol...
sign on to your aim from your home computer and reply with the number "1" to the system message that will appear telling you you are signed on from 2 locations...this should sign you off from your phone
same problem occurred on mine for the first time tonight and this worked for me
Jan 18, 2009 | Pantech Matrix Cell Phone
Picture will not display on my samsung sgh-u600
Probably the ribbon that connects screen to keypad
common fault on this phone
Aug 12, 2008 | Samsung SGH-U600
Lcd screen does not display viewfinder image
That is normal. Didital SLRs are different in this respect from digital compacts .
Sep 02, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Moultrie Game Spy I-45  Ir Game Camera Mfh-dgs-i45 Logo
23 people viewed this question
Top Moultrie Home Security Experts
Anthony Pattay
Level 1 Expert
 Mikey
Mikey
Are you a Moultrie Home Security Expert? Answer questions, earn points and help others
