Question about Refrigerators
Kenmore fridge optical icemaker hosed
Ran out of ice noticed tray full of ice but would not dispense. Optical sensor not blinking or steady...just blank. Removed ice machine checked conection, removed ice. Reseated optical sensor conections and cleaned sensors and light came back on blinking. Checked water supply hose not frozen. A day later still no ice.
  • 5 more comments
  • iceman76 Sep 27, 2007
    I checked the continuity of the motor and heater and they were both good. I jumpered T and H on the module and also jumpered the black and black white wire at the emitter and the tray heated up and rotated the teath, but never refilled with water. The emitter checks out via diagnostics. I also energized the water solenoid for freezer by swaping electrical leads with front water dispenser and water shot into fridge when actuated. I'm looking at the emitter as a suspect even though it passed diagnostics.
  • iceman76 Sep 28, 2007
    The teeth stop at 2 oclock and the gear module is on good. I ran another module test and this time I got water. Shouldn't it run through just with the thermastat jumpered? To get it to run I have to disconnect the emitter and jumper it at the connector.
    I just jumpered the black and black white wires at the emitter connector this time and it cycled through without jumpering the thermastat.
    If I leave the emitter off and leave it jumpered then the ice machine will cycle through properly. Now the the optical tests passes, but I know the emitter checks with the ice machine periodically to verify it is in the home position and then it delivers power. Is there a way to verify the ice machine is in the home position or adjust it so it is? Or where I can jumper it so it thinks its in the home position all the time so the emitter will send the voltage to the ice machine?
  • iceman76 Sep 29, 2007
    Yes.....I left the emitter jumped for a couple hours yesterday and now I have have a container half full of ice. It seems like the emitter is sensing when the door is open and closed but when it comes to sending power to the ice module it forgets.
  • KB 23 Dec 07, 2007
    I have a fairly new Kenmore side by side and the ice maker stopped working but I can still get water from the water port. When i open the freezer the optical light will flash twice with a one second delay and when I hold the emitter flapper door to unblock the beam the light stays on solid. This appears to be operating correctly. Still no ice. Ice tray is empty and does not seam to be filling with water. Water filler tube does not appear frozen. Any suggestions?
  • Anonymous Apr 13, 2009
    Same symptoms, optical icemaker dead.....IR light is on, but no ice. Where can I find out about the T & H jumpering as well as the B & B/W on the emiter?
  • 447 Answers
Ice maker module assembly is probably broken
Posted on Sep 27, 2007
  • 1 more comment
  • joey  shearer
    joey shearer Sep 28, 2007
    No the emitter is probably fine if the icemaker's module is broken it may still rotate do the teeth stop at two oclock from the front of the i/m?? does the gear on the module pull off?? it shouldnt. If all that is fine i would look to the inlet valve jumper L to v when the emitter board is jumped
  • joey  shearer
    joey shearer Sep 29, 2007
    The emitter may look to see if the internal thermostat is open or closed when it returns home but it has no other way of knowing nor does it care the i/m is energized as long as the i/maker is sensed when the bin is empty. does the i/m fill with water when u jump the emitter and you cycle it???
  • joey  shearer
    ok you have confirmed that the emitter/reciever has failed i would replace it at this point
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
My ge freezer pds22sbnso tray full of ice like no power
Posted on May 21, 2009
I have a Whirlpool Model GD5YHA. The icemaker is not making ice. The red light is blinking.
Your have not given the full model #. Anyway most likely you have the Ice Maker Optical Level Sensor.
Just red light blinking does not mean faulty here. There is a Optical Sensor check sheet. You have to follow those instructions.
Google "Whirlpool Ice Maker Optical Sensor check sheet". You will get the instruction sheet and/or youtube videos on the subject.
Not making Ice means either the ice maker is faulty or Optical sensor faulty or water valve cannot feed water due to malfunction or line frozen. Also freezer should be below - 12C to ice maker sensor to work.
Oct 25, 2017 | Whirlpool Refrigerators
My icemaker will not dispense ice. The tray is full, but won't rotate to drop cubes.
Ice sitting for a long time in the tray sometimes freezes the mechanism. Try unloading the tray of ice. Make sure nothing is jamming the parts that dispense the ice. Wait for new ice to be made and see if it works.
May 19, 2016 | Kenmore Refrigerators
Only 83 volts to icemaker
yes , when you measure in series with a load in an electrical circuit , you will measure the voltage loss the device causes by exerting its load on the supply power , this is what I suspect your seeing , if the optical sensor looks ok on the bucket thing , I suspect your having the old whirlpool water inlet solenoid problem , id ck that
try adding a small amount of water to ice form tray , if it makes ice in 24 hrs then yep you need a solenoid , also those tiny little sensors they use to sense where ice level is at , can be seen with the use of a simple home video camera (not your phone) , seems home vid cams are extra sensitive too IR light so you can view the light source with it to check it !!
Jun 06, 2017 | Kenmore Side by Side Refrigerator
Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Aug 24, 2009 | Refrigerators
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Fridge won't make ice
There is an optics test procedure you can perform on your own to confirm what the repairman says. Assuming you have a whirlpool-made Kenmore (if you have a Pur water filter at the bttom left of your unit, you do), see here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Basically, the icemaker won't initiate a harvest (dump) cycle unless the electric eye through that cutout at the top of your icemaker can see across the top of the dispenser. If the lens is dirty, or if either the emitter or receiver boards are bad, the optics won't connect. There's a simple diagnosis procedure in that pdf above. Since your fridge is from 2005 like mine, refer to the "post 2002 redesign" optics procedure. Basically the test is to open the fridge and look at the LED, then to close the flapper on the left wall of the freezer and see the change in LED behavior. This can confirm or deny an optics issue. Also, if you remove the little plastic grille at the bottom of your fridge, there'll be a piece of paper folded and stuffed in there with the diagnostic procedure in it as well. To do the full diagnostic procedure, you'll need to remove the icemaker and install a jumper, but to debug optics only, all you need to do is open the door, close the flapper, or maybe push in the door switch and look at how the LED responds.
Mar 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
1,487 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
