Mistral model MSS 10, no cold air comes out..
4 Suggested Answers
atocrxr
  • 135 Answers
SOURCE: Mistral mss 1.0kw unit - When switched on the
If the indoor unit blower is running and the outdoor unit fan is turning, you will need to make sure that the compressor itself is actually running and that it is not just the outdoor fan that is turning.
Get close and listen to the end of the unit were the compressor is located, also carefully feel the two copper lines, where they connect to the outdoor unit, they can be very hot - if working properly, so be careful.
There is no reset button that is easy to get to, the limits are usually auto resets, I would hazard a guess that the system is low on refrigerant and will require a HVAC tech.
But before that, make sure that the coils / fins on the outdoor unit are clean and not plugged with leaves, grass, cottonwood, ect.
You can turn power off to the unit and carefully wash the coil out with a garden hose, do not use a nozzle, as the higher water pressure can bent the fins.
As the water runs thru and drains off of the coil, watch and see if it is very dirty, rinse till the water is clean.
Restore power to the unit and try it, If it still does not work, the unit might be low on freon or the safeties might have been already damaged.
Once the unit is repaired, in the future make sure and keep the coil rinsed and free of any blockages.
Paul Gibson
Posted on Mar 30, 2010
Testimonial: "Thank you very much for your prompt reply. I was hoping there might be a quick simple "reset" elctrical problem. Looks like it had a ? refegerant leak"
technic_7117
  • 38 Answers
SOURCE: Mistral aircon MSS 2.0 Turns on
s.just change the thermistor coil
Posted on Aug 20, 2010
  • 320 Answers
SOURCE: Hi I have a mistral
Check if your a/c unit needs cleaning dirt's sometimes causes not to cool the air. But if your unit is clean then your compressor needs to be re-charged with freon.
Posted on Nov 12, 2010
What type of gas is used in a mistral freezer?
Depending on the year that your Mistral was made it uses either R600a or R134a refrigerant. You can go to this site and give them your model and serial number and they should be able to tell you which refrigerant that you need.
Jan 07, 2015 | Heating & Cooling
Mistral Mss15 inside fan is working but external compressor is not coming on
does outside fan run? could be capacitor, compressor, or burnt wires. recommend have capacitor tested.
Feb 19, 2014 | Heating & Cooling
Mistral mss25
Any HVAC supply house will have this.
Oct 09, 2013 | Heating & Cooling
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
Hi I have a mistral reverse cycle a/c model MSS 15 the fan works but the air coming out is not refrigerated.
Nov 12, 2010 | Heating & Cooling
My remote control will not turn on. The timer function comes on but nothing happens. model GZ-1002B-E3 mistral MSS2.6
take your chellphone and open the camera,then take the control and push any button in front of the chellphone.if the remote is ok you see a light blinking.if you didnt see the light the eye of the small plate have the problem.
Dec 09, 2009 | Hitachi RAS-09UH Air Conditioner
Stiletto 10 is not reconized by My Sirius Studio
Firmware version was too old to be reconized by new version of My Sirius Studio (MSS). Put Stiletto into recovery mode, pulled the latest driver from sirius, updated, which allowed MSS to see the unit.
Mar 27, 2008 | Sirius STILETTO 100 MP3 Player
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
