Question about Directv D10 DTV Receiver
Direct tv reciever problem - Directv D10 DTV Receiver
How do i connect my lg42lh2000 to my lg ht302 receiver so that the sound from the tv can be heard through the recivers speekers
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Aug 05, 2013 | Audio Players & Recorders
When watching cable tv we are not getting any sound from the speakers. We do get sound from all the speakers when watching a dvd or listen to the stereo. I have a Yamaha HTR 5660 receiver. All the cables...
Your best bet is to hook all your video components directly to TV, using your TV's menu to choose what you want to watch, and then hooking reciever to TV via digital optical out from TV to digital optical in on reciever. From what I read, your reciever has 6 digital optical inputs. Anyway, try running, at least, your cable box to TV, best by HDMI, the run digital optical out to reciever. Make sure you go throught he recievers menu to make sure you have he right channel selected for audio.
Jun 25, 2011 | Yamaha HTR-5660 Receiver
I suddenly get audio but no video through all hdmi inputs
If you have you video componenets patched through the reciever, then to TV, this can happen. The reciever can transfer video but, it more connections, not as effiecient, and, leaves more room for error. Your video componenets should be run directly to TV, if you TV has the inputs, via HDMI, component, or RCA the, run a single output, best, digital optical out from TV to reciever. You can use the TV's menu to choose what you are watching and, only have the one audio output from TV to reciever. You would leave the reciever at the same, Aux, Vid 2, selection all the time. You will get your best picture and best audio this way.
Jun 13, 2011 | Yamaha RX-V665 Receiver
Remote is new need to set up code for remote to access Direct TV on my Panosonic TV
Not sure if you're asking for universal remote codes for a panasonic tv, or a direct tv set-top-box, but here are both:
Panasonic codes:
0051, 0055, 0250
Your Direct TV reciever can be made by any number of companies. You may also have a combo reciever/DVR or other combo device. Whatever you have, you should be able to find the code you need here:
http://2getdtv.com/directv/directv_receiver_codes.html
Mar 14, 2011 | Televison & Video
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Can I hook these directly to my TV
No. The jacks on the back of your tv are line level. That means no power. To get the power, you need a reciever. Red and white RCA wires will go from your tv's out and the other end to an input on your reciever, and your speaker will be wired to the speaker out jacks on your reciever.
Nov 14, 2010 | Jensen JP1200 Main / Stereo Speaker
Is this tv capable of receiving digital signal from directTV
The direct tv reciever has a coax output that will send a signal to channel 3 or 4 that any older telivision can recieve...so the answer is yes. You obvously need a direct tv reciever to watch direct tv on any telivision.
Nov 26, 2009 | RCA E13319 13" TV
Program remote to a direct tv reciever
You are most likely out of luck using these as universal remotes. You are better off purchasing a Logitech remote and programing it for the Polaroid and your Directv box.
Jan 06, 2009 | Polaroid FLM-3232 Television
Directv D10 DTV Receiver Logo
20 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
