Dimplex 3000210100RP - Heating & Cooling
Where can I see the manual for the Dimplex 3087s heater
Try Googling (dimplex)(3087s)(manual) without parens.
Feb 14, 2018 | Dimplex Heating & Cooling
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Need the manual for dimplex air heater modle #6901470100
You can contact Dimplex directly, and have them email you a copy of your manual:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 14, 2013 | Dimplex Heating & Cooling
Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 25, 2012 | Dimplex Epx1250 Panel Heater
Have a melted plug on my heating stove . what causes that and what can I do
Be glad you caught that in time. The overheat or overload sensor for your electric stove-heater has failed and needs to be replaced. If it is still under warranty, Dimplex will repair or replace it at no cost. Even if it's not still under warranty, Dimplex Technical Service wants to know about this. If you live in the USA or Canada, you may call them at 888-346-7539. If you live in the UK call 0845 600 5111 and ask for Technical Service. Either Dimplex USA or Dimplex UK, can provide the part if necessary.
Do Not use your stove-heater until this is repaired.
Hope this helped you. Please let me know.
May 25, 2011 | Dimplex Compact Electric Flame Stove...
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
Heater has two settings for heat and only works on low setting most of the time.
The reason for this is the overheating sensor has cut in. It may just be malfunctioning or in fact it is overheating. This has been a reoccurring problem not just for Dimplex, but other manufacturers as well.
My best advice is contact Dimplex directly and talk with someone in their tech service dept. You can find their home page by doing a Google search for Dimplex's home page.
Jan 26, 2011 | Dimplex Heating & Cooling
Dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
Feb 05, 2009 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
