Question about Mach Speed MK8-939A (VIPERMK8939A) Motherboard
Need bios update - Mach Speed MK8-939A (VIPERMK8939A) Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
D946gzis bios.bin file i need pls help
You need to update your bios interface and to do so, CLICK HERE. It's a PDF file and all you need to do is to click on the 3rd topic which is for the BIOS Update and what you need to do are as follows:
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
Feb 16, 2011 | Intel D946GZIS Motherboard
When biosagentplus website scanned my pc, saying my bios was unknown but it can be updated.is it true? thanks hyui
NEVER NEVER
DONT UPDATE BIOS EVER
IT WILL MORE OFTEN DAMAGE YOUR BIOS
DONT..... PLS DONT UPDATE BIOS EVER.....
NO NEED TO UPDATE BIOS FOR ANYTHING.....
THE EXISITING BIOS IS OK......
IT JUST READS YOU HARDWARE AND BOOT FILES
EVEN AFTER UPDATE IT WILL DO THE SAME....SO NO NEED
DONT UPDATE BIOS OR FOR THAT MATTER ANY FIRMWARE ON ANY HARDWARES NEEDS NO UPDATING....THEY ARE MFD TO WORK THAT WAY....THEY SHOULD REMAIN THAT WAY
DONT MAKE THE MISTAKE OF BEING ADVISED BY ANY WEBSITE THAT TELLS YOU TO UPDATE FIRMWARE / BIOS....IT'S ALL USELESS
Nov 29, 2010 | Computers & Internet
Need a bios update
To update the Bios, you have to know exactly the Manufacturer, the mainboard model. You have to go to the Mainboard manufacturer Support Site to download the precise Bos file for the mainboard for the update.
A word of advice, updating the bios is not for the "novice" users. There are many precautions you need to heed before doing a bios update. Any errors during Bios update might render your mainboard useless.
Nov 01, 2010 | Computers & Internet
No update bios found for p4i45d bios 1.20
Why do you need a bios upgrade. Unless there is a specific problem you don't need to update the bios. Updating the bios and be very dangerous if you don't know much about computers. Also unless there is a specific problem with the motherboard they won't make any bios updates.
Nov 27, 2009 | Asrock P4I45D Motherboard
Pavilion dv6628us bios update on battery power?
You cannot update your BIOS on battery power because if your battery dies while updating the BIOS, your PC will not function at all because the BIOS would be corrupt. So your PC won't take the chance of that happening.... smart PC..
Your PC doesn't recognize your A/C adapter?... then you either have a bad A/C adapter, or a bad charger port on your motherboard. either way you will have to buy one or the other in order to update your BIOS.
you shouldn't NEED to update your BIOS... u can live with an older version
Sep 11, 2009 | HP Pavilion dv6628us notebook
BIOS update
It is not necessary to update your BIOS if everything is working correctly.
Jun 29, 2009 | ASUS A8N-VM Motherboard
E-Machines etower 533id PC Desktop NEED BIOS UPDATE
You only need to update bios settings if and when you get severe problems. The bios supplied with any computer is good for life of pc. normally.
But if you wish to update, visit the manufacturers site and download the bios flash utility.(that is the pc manufacturer not the bios manufacturer)
Jun 21, 2009 | Computers & Internet
I want to the bios intel motherboard d845PEBT2 place sent me
First be clear, do you want to update your BIOS & if so then go through this first: To identify your current BIOS version, check the BIOS version string:
  1. During boot, enter the BIOS setup by pressing F2.
  2. Check the Main menu.
  3. The 4-digit number after the '86A' or '86I' is the current BIOS version, as in this example: MQ96510H.86A.1663.2007.0319.1957
  4. Press Escape to exit BIOS Setup.
Important:
  • Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. We do not recommend BIOS updates for computers that do not need it. You can view all new BIOS fixes in the Release Notes included on the BIOS download page in Download Center.
  • Before initiating a BIOS update, be sure to read and precisely follow the update instructions. You may wish to print the instructions for easy reference.
  • If a BIOS update process is interrupted, your computer may not function properly. We recommend the process be done in an environment with a steady power supply (preferably with UPS).
  • All images in the examples used in the instructions are specific to certain desktop boards and are for illustration purposes only. You need to select the correct BIOS files for your desktop board.
There are up to six methods of updating an Intel® Desktop Board BIOS to the latest version. The number of options made available for any particular board may vary, depending on drive support and BIOS update file size. You only need to use one.
All BIOS update files for Intel® Desktop Boards are available on Intel(link: http://mysearch.intel.com/corporate/default.aspx?culture=en_US&q=d845PEBT2&category=all&adv=0&value=0&searchsubmit.x=30&searchsubmit.y=12).
If simply want to clear the BIOS then either remove the small battery on the MB, wait for a couple of minutes and replace it. Else close to the BIOS chip look for a 3 pin setup on the mother boar with a jumper on two pins Remove the jumper, wait for 10-20 seconds & replace it. That will clear the BIOS.
A word of caution, do not update the BIOS if your PC is working properly. Do it when prompted to,during installing a new software or hardware this message will pop up on the screen.................sodeep
May 15, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Updating BIOS
Different computers different files
You need two files to do the Job read instructions carefully
1 is for bios the other is the program that install it
Aug 30, 2008 | Intel Motherboard
Mach Speed MK8-939A (VIPERMK8939A) Motherboard Logo
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Gareth Cockram
Gareth Cockram
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
