Question about Sony DAV-BC150 System
No remote canot turn radio stations - Sony DAV-BC150 System
Why can i only get radio stations from our humax freesat and not tv channels
There is a button on the remote labelled 'TV/Radio' which was probably knocked when the remote was dropped.
Sep 15, 2014 | Humax Televison & Video
Tip
How to use your iPod as a radio.
Connect the iPod Radio Remote to your iPod Nano by plugging it into the dock connector. Plug your headphones into the port at the top of the Radio Remote, next to the hold switch.
Once the Radio Remote is connected, select "Music" and then "Radio" on your iPod. The Radio Remote will automatically tune in to the first available station it finds. The iPod screen will show the radio station and any other available information or data.
Press the center button on the iPod. Use your iPod click wheel to find other stations. Once you have found your favorite station, hold the "Center" button down until a triangle appears on the radio dialer on your iPod screen.
Step4 Once you have set up all of your favorite radio stations, use the "Next/Fast-Forward" or "Previous/Rewind" buttons to navigate between them.
on Feb 11, 2010 | Computers & Internet
I need remote code for sony xdr-ds12ip i pod docking station
call sony and request or check amazon. usually you can download an app for your iphone for remotes or you can try a universal remote. program it to your dock radio station
May 06, 2011 | Sony HD Radio and Dock Docking Station,...
How do i get the radio to work
Besides playing your favorite songs and custom playlists, you can also listen to your favorite DJs and talk shows on your iPod Nano by using it as a radio.
The iPod Radio Remote is a small and convenient accessory that lets you tune in to live radio when you're on the go, and also allows you to remotely control your iPod. Here is how you can easily setup Radio Remote on your iPod Nano and start using it as a radio.
  1. Connect the ipod Radio Remote to your iPod Nano by plugging it into the dock connector. Plug your headphones into the port at the top of the Radio Remote, next to the hold switch.
  2. Once the Radio Remote is connected, select "Music" and then "Radio" on your iPod. The Radio Remote will automatically tune in to the first available station it finds. The iPod screen will show the radio station and any other available information or data.
  3. Press the center button on the iPod. Use your iPod click wheel to find other stations. Once you have found your favorite station, hold the "Center" button down until a triangle appears on the radio dialer on your iPod screen.
  4. Once you have set up all of your favorite radio stations, use the "Next/Fast-Forward" or "Previous/Rewind" buttons to navigate between them.
Good luck.
Apr 28, 2010 | Apple iPod nano
Radio
Feb 11, 2010 | Apple iPod nano
How do I place a station permanently on my remote control ?
I believe if you program it in the radio, the remote will also choose that station. Put the tuner on the station, press and hold the number on the radio where you want that station to reside, wait for the double beep, and then try your remote
Jan 08, 2009 | Bose Wave Radio
Radio without remote
Press Function button at front of unit until display shows Tuner, and press Preset + / Preset -
If you want to listen Non-Preset stations, press << / >> keys of remote to tune a station. That's the procedure.
If built-in remote in your mobile have above said << / >> keys, you can tune station frequency.
Nov 10, 2008 | Audio Players & Recorders
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | Audio Players & Recorders
Remote
Tune the radio to the station you want using the up and down tuning indicators then select a button on the remote for that station and mash it for several seconds and that button should be set for that frequency.  You might have to do the selection on the radio itself instead of just using the remote but once the buttons are assigned they will work with the remote.
Dec 27, 2007 | Bose Wave Radio
Sony DAV-BC150 System Logo
14 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
