Question about Whirlpool Duet Steam WFW95HEXW
I have a code e01 F09 on my duet steam WFW95HEXW0
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
Daniel S
  • 4323 Answers
SOURCE: Duet Washing Machine has E01 and F09 eror codes.
Hi
F09 error is a overflow error and is displayed when the overflow contact on the pressure switch is closed for more then 60seconds. First make sure that the drain pump assembly located inside the lower access panel is not clogged then check the wire harness connections to the drain pump, pressure switch and the central control unit. If everything is fine then the pressure switch should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 30, 2011
dmftrucker
  • 1922 Answers
SOURCE: Whirlpool duet f09 error code
it is an overflow condition caused by either a plugged drain pump or a bad pressure switch,if you hit pause/cancel and the drain pump continues to run then check the drain pump cleanout for foreign objects
Posted on Sep 01, 2012
My F09 and my E01 codes keep coming on in mid cycle and shutting down the cycle
F09/E01 are related codes.
LONG DRAIN: If the drain time exceeds 8 minutes without reaching reset level in pressure sensor, the valves are turned off and the drain pump will stop running. NOTE: Suds can cause delays in draining. Washer drains for 4 minutes, pauses 5 minutes, then tries again for 4 additional minutes of draining. F9E1 will display if washer does not drain. (Normal drain takes less than 2 minutes)
Possible Causes:
Verify that the drain hose is not blocked or kinked.
Make sure drain hose is not sealed into drain pipe.
Make sure the drain hose height does not exceed 96" (2.4 m).
Check/clean drain pump filter of foreign objects.
Check connections from tub to air trap, air trap to pressure hose, and pressure hose to pressure sensor.
See TEST #8 (Drain Pump) on page 19. Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?
Oct 03, 2016 | Whirlpool Washing Machines
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Feb 16, 2014 | Whirlpool Duet 4.3 cu. ft. Front Load...
Error code f09 e01
Did you clean the tube that goes from the tub to the drain filter then the drain pump it is behind the front panel also make sure there is nothing in the drain pump stopping the impeller from turning.
Jan 29, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
I have a whirlpool duet steam and reads codes F06 E 02 and replaced the electric controller and now reads F06 E01
OK your almost there. The switch or Latch that locks the door is faulty or bad. It is either that or probably not connected to the right terminal. New control board!!! That was expensive! Good luck!
Jan 16, 2014 | Washing Machines
Error code F06 and E01
Here is what the F06 code stands for
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Dec 14, 2013 | Whirlpool Duet Steam WFW95HEXW
My front load washer had a f09 then e01 code come up today. I think something is clogging somewhere
blankets can be very heavy and ball up on one side of the washer during spin cycle and cause the washer to shut down do to inballance... remove blankets & spread them ou if the are twisted up also mabe leave one of them out and rinse separatly..
Jul 09, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F09 error code for whirlpool Model GHW9250MT
Please click on the following link for an explanation of the "F09" error code:
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
Read through the information thoroughly and let me know if you have any questions, or require further assistance. I hope this helps you.
Jul 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam WFW95HEXW Logo
180 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
