Question about Iwill XP4evo Barebone
My XP4evo don't boot + paintful alarm
My XP4evo (3 years old), don't boot and now there is some kind of alarm (very paintful) ringing. Any idea what that means ? Thanks for your help
  • cperin Sep 30, 2007
    Thank you so much ! I changed the memory I know it's working perfectly !
    Regards
    Christophe
If when you try and switch it on, you get a long system beep of about 4 seconds, a pause, then that beep again - meanwhile the monitor stays blank, then that happened to me recently. It happened after I put different memory in it, and was because i hadn't pushed the new ram in firmly enough. It's partly a guess, but either your ram might have somehow come loose? or maybe the memory is knackered. Make sure you only get 184 pin 266mhz pc2100 memory, as anything newer won't work. Hope that helps.
Posted on Sep 28, 2007
SOURCE:
Can I repaint the rust parts in the bottom of the micro wave oven and what kind of paint can be used?
Hello -
Yes the rusted areas inside a microwave oven can be repainted.
First, you will need appliance paint which is designated for microwave interior use. Check with your local hardware store or local home improvements store to find out what paints they sell which fit the criteria for "microwave cavity paint."
You can read directions for how to go about the project:
https://www.doityourself.com/stry/how-to-repaint-the-inside-of-a-microwave
Read the instructions through, completely, before starting on your project so you know what supplies you need to have available and what steps need to be followed before starting.
Best wishes.
Jul 01, 2018 | In Microwave Ovens
My Kidde 10 year battery operated smoke alarm will not stop beeping. Only a few months old...driving me mad, what's the matter with it
remove battery and replace with a new one --was their any work done in home --spray paint -polyurethane-oil paint --by a heat source --fumes and heater locations can set off the unit but replace batty and push test button
Oct 30, 2016 | Home
Is there a problem with the factory paint
The truck is 17 years old & you ask now?
Doubt the factory would remember back
17 years, when it was built
You want a free paint job don't you?
Jun 12, 2012 | 1995 Jeep Cherokee
What kind of paint and brush should I use to paint my wooden bar stools?
You should first put a layer of primer using wood primerfrom a spray can. This will prevent thepaint from being absorbed into the wood. After 24 hours, you should use acrylic black (or whichever color youwant) paint in a spray can. The reason Irecommend spray paint is because it's easy and gives you tan even, blemish freecolor. Wait 24 hours (so that bubbleswon't form) and do another layer. If itdoesn't look thick enough to you, wait another 24 hours and do a final layer. There is no need for a clear finish.
May 29, 2012 | Furniture
My Thinkpad G41 does not boot up, nothing comes up
Hello
Have you tried swapping out ram modules? This would probably be the cheapest. And, a faulty ram module gives a beep code. Try it, and let me know.
Kind regards
Andrea
Apr 21, 2010 | IBM ThinkPad G41 Notebook
LG env3 alarm clock vibrate
Yeah, I had that problem too. I thought my phone was broken. -_- My old phone from Verizon is like 4 years old and I JUST got my enV3. On my old phone, I'd have to set the alarm's ringtone to "no ring." But, on my enV3, "no ring" literally means NO ring, no vibration, no notification, no nothing. On the enV3, in order to set your alarm clock to vibration mode, all you have to do is make sure you "master volume" is in vibration mode, but you have to set your alarm's ringtone to something other than "no ring."
Oct 20, 2009 | LG enV3 VX9200 Cell Phone
CHIPPED PAINT ON BATHROOM SINK DRAIN STOPPER
you need to remove the brass ring from the tub and buy acan of spray paint for metal you will be able to find it in a brass finish
Jan 28, 2009 | Home
Alarm and ringtones only occassionally go off - LG TU500 (CU500)
i know theres a factory reset in the phones test mode. to get to it press 277634#*# on the phones main screen. not sure if it will help you to much but its worth a try. let me know if it works
Dec 22, 2008 | LG CU500 Cellular Phone
My sharp microwave oven sparks and pops when in use.
1. You have to clean m/w inside from all kind of grease and food resedue.
2. Inspected m/w cavity inside and clean all burning spots with sand paper.
3.Apply touch paint on this spots.
Different color touch paint you can buy at any appliance patrs store.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 01, 2008 | Sharp Microwave Ovens
Alarm clock, LG Shine phone
I just "personalised" the outdoor profile to set the message alert to silent, while still keeping the ring volume on high.
I also picked the divert call option so the phone doesn't ring.
So I just change the phone profile before I go to sleep and divert my calls.
Kind of an awkward solution..I'm considering getting an alarm clock or just using my old phone's alarm clock
Feb 19, 2008 | LG Shine KE970 Cellular Phone
Iwill XP4evo Barebone Logo
348 people viewed this question
Top Iwill Computers & Internet Experts
Ekse
Alun Cox
Robert McClure
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
