Question about Casio FX-9860G Graphic Calculator
How to solve : x(25i)+y(25i)=20+50i; X(25i)+y(40-25i)=-50i . In casio fx-991ES PlUS
  • Casio Master
  • 7,993 Answers
This simple calculator can barely perform single operations on complex number, and cannot solve linear equations with complex coefficients.
Posted on Oct 29, 2013
    Sergeant:
  • Casio Expert
  • 263 Answers
See cap image below
How to solve : x(25i)+y(25i)=20+50i;               - 49284531-37e0-4f77-9418-0d3dcf9098e6.jpg
Posted on Oct 21, 2013
  • 7993 Answers
SOURCE: mode change
Just so that we know what we are talking about. The natural display is the display mode in which fractions appear on two lines, radicals appear as radicals, log can be calculated in any base, etc. If that is what you understand by Natural Display, we are in agreement.
To set this mode, you turn calculator ON and press [SHIFT][MODE] (setup). The option is called MathIO, and it has the number 1.
Thus [SHIFT][MODE][1:MathIO].
Hope it helps.
Posted on Oct 13, 2009
  • 7993 Answers
SOURCE: when i press the MODE button in my CASIO fx - 911ES
Just in case : Press [SHIFT][CLR] (9) [3: ALL] to reset the calculator and try [MODE] again.
If that does not work, your calculator may be defective or a fake (not the genuine article). If at all possible, return it to where you bought it and get a refund.
Here is a picture of the FX-115ES, its face looks like the 991ES. Hope I am mistaken.
Posted on Oct 18, 2009
  • 7993 Answers
SOURCE: can you show how to convert pola to rectangular o
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Posted on Nov 15, 2009
Testimonial: "thanx that was very helpful"
  • 7993 Answers
SOURCE: How can I solve a matrix on my Casio fx-9750GA
If you have mastered matrix manipulations on the TI calculators, it should be a breeze to learn the same on the Casios.
A. Define the matrix (Create it)
  1. Turn calculator ON.
  2. Press Menu,select the MAT icon and press [EXE]
  3. You see a list of possible matrix labels (A, B, C,D,E,F)
  4. All that have not been created have a "none" to their right
  5. Highlight a matrix name and press the right arrow. Where there was "none" , you have a template 0x0.
  6. That is where you specify the dimensions (mxn). exemple. 2x2
  7. Enter the first dimension and press [EXE]
  8. Enter the 2nd dimension and press [EXE]
  9. A matrix template opens where you enter the coefficients left to right and up down.
  10. After each coefficient press [EXE]. Cursor moves to the next coefficient, etc.
At the bottom of the screen you have 3 menus for Row and column manipulations. But those will have to wait for now.
Press [SHIFT][QUIT] to return to the list of matrices to create new ones
Operations on matrices
Once you have one matrix, you can do operations on it: Calculate the determinant (if matrix is square), calculate its inverse, transpose, augment it, fill it, etc..
  1. These operations are accessed as follows.
  2. Quit the matrix editor by pressing [Menu] and selecting the [Run] application.
  3. Press [OPTN][F2:MAT]
  4. You have the menus Mat,M(atrix)->L(ist), Det(erminant), Trn (transpose), Aug(ment) ->, Iden(tity),Dim(ension) Fill
Exemple : calculate the determinant of a matrix A (already defined).
  1. You press the [OPTN][F2:MAT] key sequence (just above)
  2. Press [F3:Det]; the command det is displayed on screen.
  3. Press [F1:Mat] the identifier Mat is displayed.
  4. Press [ALPHA] A; screen display det Mat A.
  5. Press [EXE] to get the value of the determinant.
Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A ^2 [EXE]
Product of two compatible matrices MatAXMatB
[OPTN][F2:MAT] (MAT) [Alpha] A [* ) (MAT) [ALPHA] B [EXE]
Hope it helps.
Thank you for using FixYa.
Posted on Nov 23, 2009
  • 7993 Answers
SOURCE: how to solve for a
There is no button but a menu tab.
In Run screen, enter the number whose factorial you want to calculate ( number can be at most equal to 69), press [OPTN][F6] to get to next page of menus.
For factorials
  • Press then [F3](PROB) then [F1] (x!) followed by [EXE].
For combinations
  • Press then [F3](PROB) then[F3][nCr][EXE]
For permutations
  • Press then [F3](PROB) then[F2][nPr][EXE]
Posted on Oct 01, 2010
What does the MU/MD key on the Casio HR-100TM do?
Here's how to use the MU/MD key. Say you want your item that COSTS you $120 to be priced such that you end up with a 40% margin. MU'MD calculates the final price to achieve the margin.
Enter: 120 X
Enter: 40 MU'MD
Result: 200.00
Proof: 200 - 120 = 80 / 200 = 40%
Essentially the same as using the COST/ SELL/ MAR keys.
The Casio HR-100Tm manual is pretty pathetic. Expected a better one on their website, but alas.
Jan 03, 2017 | Casio HR-100TM Printing Calculator - 12...
How many liters of 20% alcohol solution should be added to 40 liters of 50% alcohol solution to make 30% solution
I will assume that the percentage is per volume (20% per volume, 40 per volume.
Let x be the number of liters of the 20% solution.
What is the volume of alcohol in x-liters @20%?-----> .2x
What is the volume of alcohol in the 40 liters of solution @ 50%? Obviously 20 liters.
Amount of alcohol in the two solutions =.2x+20
After you mix the two solutions what is the resulting volume?
Resultant volume=x+40
Percentage of alcohol in final solution: 30% or 0.3
Quantity of alcohol in final solution =.3*(x+40)
When mixing the two solutions, no alcohol is lost: The amount of alcohol before mixing is equal to the volume of alcohol after mixing
(.2*x+.5*40) =.3*(x+40)
Solve this equation for x. (Show your work) You get x=36 Liters.
Check the result by replacing x in the equation.
Nov 12, 2013 | Casio FX-300MS Calculator
Casio fx-83es
3.28 squared is 10.7584 .
10.7584 times 40 is 430.336 .
It appears your calculator is correct. I get the same result on multiple calculators, as well as by hand.
Let's work this backwards:
431.8 divided by 40 is 10.795 .
The square root of 10.795 is about 3.28557 .
Feb 01, 2012 | Casio FX83ES Scientific Calculator
I have a casio sport sea pathfinder spf-40 I cannot find my manual and the alarm keeps going off, one at 12 midnight and one at 7.15am and i cant remember how to turn it off please help ? andy
I had this problem with the Casio 2926 at midnight for many weeks and no matter which buttons I pressed, it carried on.
I solved it on my model, by going into alarm set mode (AL) by toggling button on lower left of watch face. Then using button on lower right, cycle through all (5?) alarm options and also check the tiny screen new the rim at top right of watch face marked with SNZ ALM SIG. If a little black box shows up on this screen, switch off the alarm or snooze, by pressing the button on top right.
Otherwise go to Casio and go through their instructions. The watch is not designed for easy use.
Oct 28, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Problem with casio sea-pathfinder watch
For all Casio watches go to www.casio.com select "Support" then "Manuals" then "Watches".
You will then be able to enter the 4 digit number in the square box to get the manual for your watch or module inside is actually what the instructions refer to.
The problem of changing functions automatically is called "Auto Display" and can be stopped and started in Sea-Pathfinder SPF-40 (modue 2273) by pressing the bottom left button for 3 seconds.
Nov 13, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Weather casio FX-115ES can solve 5*5 matrix
According to the manual for the Casio FX115ES, the largest matrix it solves is a 3x3.
Sep 06, 2008 | Casio FX-115ES Scientific Calculator
Casio cmd-40
what's the price f the motor of casio md-40
Jul 13, 2008 | Casio Watches
Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
Nov 19, 2007 | Casio PRG-40T-7 Pathfinder
Casio QV-40
To tell you the truth.....NO. You can buy a new casio camera for cheaper than fixing your old QV. Alot of times too the QV isn't going to be compatible with XP or VISTA.
Oct 26, 2007 | Casio QV-R40 Digital Camera
Casio FX-9860G Graphic Calculator Logo
181 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
