Question about 5101 LE 1 Way Car Remote Starter System
Remote do Not Work After Replace Car battery - 5101 LE 1 Way Car Remote Starter System
How come door look don't work, light in the don't work, dim light on open doors ?
First if you have another remote (FOB) try it. If it works problem solved.Replace the battery. Replaced the battery in both fobs. The only other thing it could be is the reciever in the car. Dealer time.
Aug 01, 2014 | Kia Rondo Cars & Trucks
Keyless remote wont work
when you replace the batteries you may have to have the fob key reprogrammed to the immobiliser in the car. Any dealer service centre can do it for you.
Dec 23, 2013 | Dodge Cars & Trucks
My remote will not work. never has and i bought it brand new.
Check and make sure the battery is installed in the remote. If it is installed, check for the correct installation. If this is correct, replace the battery. If it still doesn't work, you might have a faulty remote.
Apr 12, 2011 | Jensen Vm9214 Car Video Player
How do you get the Car to chirp when you lock doors or shut car off, in other words the horn unlock is not activated
try a new battery in remote or if you have a spare remote try it. If that doesnt work try removeing battery terminal off of car battery for 30 minutes than replace cable and give it a try.
Nov 24, 2010 | 2007 Chevrolet Cobalt Coupe
Remote key fob does not unlock or lock car
It may just be a battery problem. Replace the battery of your remote fob. If it will not work, try to reposition the controller beneath the dashboard.
May 27, 2009 | 2005 Suzuki Swift
Key remote won't work - had car 28 days can't reprogram electrical prob with car
have them check the remote. mine was broken, and dealer said the battery was good, but couldnt get it program. . dealer replace the remote. and it worked..
May 21, 2009 | 2006 Chevrolet Malibu
Jeep one year old. Keyless just stopped working. Engine starts for a second then cuts off. Replaced battery in key/remote and still doesn't work. Now alarm sounds if opened with the key the old...
Assuming you have a second key try using that one to deactivate the alarm, if not replace battery in remote. Does lock and unlock work now? you will need to get the remote operational to disengage the security feature that will not allow car to start.
if not disconnect the car battery let sit for 15 min to reset system try again..make sure bettery in remote is installed properly.
Nov 28, 2008 | Jeep Wrangler Cars & Trucks
I was leavng my house and i opend the door with mi key instead o the remote car alarm went off but the remote is dead is thar another way i coud shut it off
Here's some things to try:
1) start car with key, then turn off, it may reset the alarm.
2) replace battery in remote
3) place remote in freezer for 30 min or so , it may refresh the battery enough to work for a little while.
Oct 26, 2008 | Chrysler Concorde Cars & Trucks
Remote control problems
Replace your battery in the remote. Dont leave something sitting on the remote that is pressing a button down, or it will drain your battery
Jul 06, 2008 | Jensen VM9020TS Car DVD Player
5101 LE 1 Way Car Remote Starter System Logo
15 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
