Question about Honeywell TH9421C1004 VisionPRO IAQ Total Home Comfort System
Honeywell TH9421C1004 not available only wifi is it compatible
How do you change the battery on Honeywell Th9421C1004 Thermo
Hello Bob Compher,
It looks like GETTING that battery is the biggest challenge...
After that it simply unplugs (like a portable phone battery).
Your manual is listed (below)
For assistance with this product please visit or call Honeywell Customer Care toll-free at
1-800-468-1502
Homepage
Honeywell VisionPRO IAQ Installation Manual Page 8
Feb 24, 2017 | Honeywell Heating & Cooling
Honeywell thermostat th9421c1004
contact honeywell tech support
Jul 21, 2016 | Heating & Cooling
Honeywell TH9421C1004 blank after power outage. How dove ss I turn it back on?
Remove your thermostat from the wall and you probably will find a battery compartment in the rear.
Sep 01, 2014 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Honeywell TH9421C1004 blank screen after power outage
We'd love to help resolve this. Please give us a call at 1.855.733.5465 and our customer support team will be happy to troubleshoot with you.
Auto does not show in system
On Honeywell thermostats you have to program the thermostat on the setup mode to have the auto to be on the display. The setup instructions will walk up through it. If you do not have them, you can down load them to you computer.
Jul 20, 2014 | Honeywell TH9421C1004 VisionPRO IAQ Total...
TH9421C1004 touch screen stopped working
Make sure there is 24 Volts between the R & Common wires connected to the thermostat subbase.
Dec 13, 2013 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Honeywell Instruction Manuals
The power on many of those units is derived from the unit itself. Check the control fuse on your furnace, or check the breaker, or switch, or other power source to the unit. But remember, there is a problem. Be very careful or you know what you are doing or you could burn your house down or hurt somebody.
Nov 02, 2013 | Heating & Cooling
Blank Screen on thermostat
check your float switch. On your air hander you have 3/4 white pvc coming out of bottom of unit, where the water drains out. If you have a float and your drain line is plugged it will make your tstat go blank. vacuum the drain line where it comes out of the ground outside.
Jun 19, 2013 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Thermostat
That thermostat must be used with a THM5421C1008 Equipment Interface Module. The thermostat communicates with the module and the module is connected to the HVAC components.
Feb 08, 2008 | Honeywell Electronic Programmable...
Honeywell TH9421C1004 VisionPRO IAQ Total Home Comfort System Logo
88 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
