Question about Dell OptiPlex GX270 PC Desktop
Cable monitor signal
It will show windows xp for a bit then it goes off, but i can go into all my setting and stuff and its fine
    Sergeant:
  • Dell Expert
  • 464 Answers
First go to device manager and click on Display to see what Video Driver you have
How do get into Windows Device Manager
Second go to Dell.com to get driver
heres the link for you
Product Support Dell US
Go and click on the list on Video (6) file in blue lettering you must scroll down the page to find it.
Find which one is yours and download it and install it.
Once you did that and it still does it. Inspect the cable from the back of the monitor to the back of the computer. Make sure the connections are good and secure.
if that doesn't work them check to see if your computer have a video card or if its intergrated. If you have a video card reseat the card by opening the system the same link i provided you has a Service manual that can show you how to do this.
if it doesnt have a video card then you can buy one to rerplace the bad graphics chip on your computer.
hope that helps
Posted on May 14, 2014
3 Suggested Answers
proton77
  • 1183 Answers
SOURCE: blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Posted on Oct 11, 2008
  • 3940 Answers
SOURCE: monitor
Install the Drivers. The CD you received is just the basic Windows Install. You can download the drivers at support.dell.com Install order: Desktop System Software (If available) Chipset utility Video Driver Audio Driver Network Driver then install applications like Roxio/Sonic and DVD player
Posted on Sep 30, 2009
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
Cpu powers on. Monitor goes to Windows XP and
Dear, This is due loose connection of power cable
(which connect from CPU TO MONITOR). Just check your power, m sure ur problem would be fix out.
Feb 01, 2010 | Generic Memory Compaq Presario SR1215CL by...
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Monitor goes to BIOS Screen Repeatedly
Your monitor is fine, the problem here is with your computer, and sounds like a virus. Time to competely reinstall windows, or have a tech look at the computer.
Aug 01, 2009 | Microsoft Windows XP Professional SP2 Full...
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
BenQ Monitor ' Out Of Range '
check your resolution settings and change to 800><600 and try again.If it does not work at 1024><768 try loading monitor driver In display properties it should show BenQ FP731 instead of plug and play monitor.
Samir
Oct 29, 2008 | BenQ FP731 17" LCD Monitor
No Signal when desktop wants to load
It does not hate that monitor. I believe the problem is in the settings on your video. Your monitor cannot display them. You will most likely need to start your computer in safe mode and change the display settings on your video card or, alternatively, download updated video drivers. Also, if you can't get Windows to start in normal or safe mode, one of the options you get when you press F8 on startup is to start in VGA mode. That will get you in so you can tweak your settings, which are probably set to a resolution too high for your monitor.
Sep 11, 2008 | ViewSonic VA1916w LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell OptiPlex GX270 PC Desktop Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
