Question about Belling BIM60 Microwave Oven
Crackling noise when microwave plugged in - Belling BIM60 Microwave Oven
Is it normal for a microwave to make crackling noises when standing and not in use but plugged in ?
A microwave in standby mode should not crackle. There might be a slight humming sound from a transformer, but that should be all the noise it makes. You could have a transformer or control panel component that is failing.
Oct 28, 2016 | In Microwave Ovens
The coating on the bottom under the turntable is peeling off and there is a crackling noise and more peeling going on if
Please stop using and discard, it can be very dangerous to use it like this, fire, explosive, poison hazzard
Jan 31, 2016 | Microwave Ovens
I have a prestige se20 microwave and when you out
You wrote, " ... and when you out it in it makes a weird noise ...." Huh? out it in it???? I have no idea what you're talking about.
Oct 20, 2014 | Microwave Ovens
My kitchen aid microwave makes a loud crackling noise every once in awhild
Is it a carousel (turning platter)? if it is, than it is probably dirt on the platter support wheels and the platter support groove/track on the bottom of the oven, clean the glass plate, the support wheels, and the bottom groove as well, if you want to make sure the crackling comes from the carousel system, take it all out (support and platter) than place a glass of water in the oven and start it, if there are no crackling noise than my theory is correct, if the noise is still there than have it checked by a professional technician...
Sep 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
Rattling, crackling type noise just started and is constant when microwave is running.
A couple of months ago my microwave started making crackling, rattling and grinding sounds everytime i used it and i thought it was going to break down. It turned out one of my children must have spillled or overflowed something with a clear liquid because the micro did not look dirty but there was a crunchy substance under the wheels of the turntable. Once i cleaned this up totally the noises all went away.
Jan 19, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Belling BIM60 Microwave Oven Logo
24 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
ray gallant
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
