Question about Kenmore 3.2 cu. ft. Top Load Washer
Leveling a washer tub
I need to know how to level the tub of a kenmore 80 series washer
  • 2 more comments
  • katie king Sep 28, 2007
    well on my machine the tub is off tilt and needs to be leveled
  • katie king Sep 30, 2007
    as a matter of fact i was told by a repair man that there are springs inside... i did not mean your advice was wrong or anything i just meant it did not help me with my problem... i am very sorry if i worded it wrong and hurt you feelings .. please forgive me...
  • Anonymous Mar 19, 2014
  • Anonymous Mar 21, 2014
    Need to know where, in the Phoenix/Chandler, AZ area, I can buy a refurbished Kenmore washer. Interested in 1994 and newer. Thanks
I recently had my machine serviced and the tub was sitting crooked and noisy as hell after it was put back together. I opened up the machine and looked at the bottom of the tub and the part where the springs are attached. The triangular tray in between the tub and the frame shifted while the machine was on its side. The tray is meant to center the tub on the frame and has some plastic bushings on the three corners. Tilt the machine back a bit, put something under the frame of the machine so it doesn't come down on you. If you know how, take off the agitator and have someone lift up on the tub an inch or two while you reposition the tray. The tray will fit only one way, but it can come loose while the tub is lifted up a bit and properly aligned. Look for some bushings or plastic spaces on the corners of the tray. Once I centered the tray and stood the machine back up straight, the tub was centered properly and runs like a champ.
Posted on Mar 22, 2008
  • 447 Answers
You dont level the tub, level the feet on the bottom of the machine
Posted on Sep 27, 2007
  • joey  shearer
    joey shearer Sep 28, 2007
    well thanks for saying my advice is not helpful, i tried, there is no such thing as "leveling the tub"
  • joey  shearer
    joey shearer Sep 30, 2007
    i forgive you .....was a spring broken??
2 Suggested Answers
  • 77 Answers
SOURCE: washer tub level
if you could post the model number found just inside the lid, I will be able to provide a more precise description of what you need to do.
Posted on Sep 28, 2007
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Washer tub level
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore series 80 washer does not fill up all the way with water even when it is on full load.
on most top load washer the level of water should be no more tha 13 inches of water on a empty tub.the rule of thumb is there should be between two to three holes visible above the water line
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 80 Series clothes washer and the tub will overfill about once a year. How do I fix it?
adjust the water level control...the thing with a small hose on it that goes to the tub
Aug 04, 2009 | Washing Machines
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Open Questions:
See all Kenmore 3.2 cu. ft. Top Load Washer Questions
Kenmore 3.2 cu. ft. Top Load Washer Logo
327 people viewed this question
Sal De
 Brian Main
Brian Main
