Question about RCA D6520
Unit Very warm to hot
I have been operating the RCA D6520 multi-switch for a couple of years with four receivers. System works well but I noticed quite by accident (switch in attic) that the switch was very, very warm (almost hot). I wonder if this is normal or should I be alarmed?? Thanks in advance for your thoughts. Phil
It is not normal. This should alarm you. Any device that has warm-hot surface, manifest internal problems and should be given extra attention.
Posted on Sep 29, 2007
This is an alarm for u. it should warm but normal, if it is very warm, it will create some problem in future. so be aleart. good luck puru
Royal dometic. not sure year or model. started cooling several days after power defrost kicked in second time there was frost buildup and now neither fridge or freezer will get cold..have...
When you feel cooling unit from outside behind cover and unit is on for a couple of hours min, does it feel warm, hot? describe any other things you notice please.
Apr 09, 2013 | Refrigerators
My ceiling fan does not work.It is a Hampton Bay. There is power.
Hampton Bay receivers are notorious for taking a dump, replace the remote. If you're just adding the remote... There will be 6 wires on the remote, a set of two (white and black) a set of three (white black red or blue) and a single small wire by itself. The single wire by itself is the Antenna wire, do not wire it to anything, or it will fry the board in the receiver.
Mar 31, 2010 | Hampton Bay 52 In.Carriage House II in...
H20-600 Overheating causing "Searching for Satelite" Code 771
I had a H20-600 that worked consistently until I unplugged it, then it would not power up unless the unit was warmed to its operating temp. (I placed it on an old iron radiator, warmed it up, it then powered up). The power supply on the unit had several failed, crowned capacitors (3300uf/10v). I pulled them, tested them (one was bad), and then replaced with good caps. Up the unit came. The PS in this unit is a switching unit and needs healthy caps to oscillate and create sub voltages. The standing heat in the unit makes the caps get hot, crown and leak. See any brown sputum on the top of a capacitor and it is on the road to failure.
Jul 31, 2009 | Philips DIRECTV H20 DTV Receiver
4position lnb ineed to know which termanal to hook uo to for a
do you mean 4 outputs if so it dont matter but for some reason i always use the one on the left first
Mar 19, 2009 | RCA D6520
Receiver switches to standby without notice
This receiver is likely to be overheating or has a shorted speaker wire. If the unit is very warm when it shuts down then it is in need of some additional ventilation. Onkyo's tend to run hot so this is critical for proper operation. A speaker wire problem could also cause an issue when the unit detecs a no load situation.
Feb 25, 2009 | Onkyo TX-SR803 Receiver
Denon AVR-4802R automatically shuts off in multi-zone mode
i had the volume of the multi-zone tuned too high and was attenuating it in an external control box. Once i took the multi-zone volume down to -25db, the problem went way. My main zone was operating around -35db so did not have the problem.
Nov 23, 2008 | Denon AVR-4802 Receiver
RE: Carrier Unit Central
Try first cutting system power for a couple of minutes, even from main. With some luck it can be enough to reset the system, as it looks like a problem with the control board. The control board has also a coin battery and a reset bridge on it , but to access them you need to take apart control unit. Try fist turning off main power switch for 5 minutes or so.
Jul 26, 2008 | Heating & Cooling
How to vary the Multi zone levels at the receiver
Try putting amp to zone 2 go to set up menu for "variable" volume adjust and turn down the volume with the remote control volume buttons or use the volume control on the amp,this should work,i had the same problem with a YAMAHA amp and this worked.
hope this helps.
Jul 16, 2008 | Denon AVR-3802 Receiver
Rt2250 rt2500 speaker static noise hum buzz until fully warmed up
It sounds like a capacitor in the power supply is just about to die. With the power disconnected have a look at the large tin can looking gizmos near the power transformer. There could be a couple of them. Leave the unit switched off for a while before going near them they could still pack a splat. Replace them with the same value and make sure they're connected the right way and it should solve your problem. Whilst in there have a good look for any other smaller capacitors which look as if they're getting rounded at the top. Replace them too. Either that or dig deep and buy a new one.
Oct 23, 2005 | RCA RT2250 System
RCA D6520 Logo
113 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
David Payne
David Payne
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
