Question about Uniden Bcd996xt Scanner
My bcd996xf scanner is a peace of junk it is rip off for the price of 500 dollars
How much is the a4tech webcam
The usual price for this item is about $24.95.
Have a nice day!
Jul 20, 2011 | A4tech PK-635 Webcam
Kenmore fridge leaks water and stops cooling. Tech came out and said it was a heater/defroster unit that would cost $500. Sounds correct?
$500 for a defrost heater replacement? Rip off city ! Don't know for sure what prices are in your area, but around here, that's about 3x what it should be.
Mar 31, 2011 | Kenmore Refrigerators
1997 grand am gt needs front brakes. friend took to shop and just for front rotors it costs over 500. is this even possible. it was initially told to me it would only be 150 for front rotors including...
No way, they are ripping you big time, Shops make money on brake jobs, but that is a little extreme. I would call rip-off alert and report that one. The $150 price is a little more reasonable. Even if you have to go to the junk yard for rotors, Changing the pads is a one hour job, and depending how the rotors are attached, 2 more hours at the most plus, pads, $30, plus rotors, $100 max, It sounds like they might have quoted the wrong price to start and then tried to squirm out of it by telling you it was going to be $500. Get another quote or do it yourself. Hope this helps.
Mar 20, 2011 | 1997 Pontiac Grand Am
How much it's cost please ?
Digital cameras costs above several hundred dollars depending on the brand names and featuree functions. Brand names like sony, philips, panasonic, fuji, samsung digital cameras with features picture video, lenses, storages spaces cost above $500 least considering warantees, and peripheral compartment. Tripod stands, camera batteries, recording chips, carry cases, charger kits, costs differently depenign on the brands names, availability at retain and buyers choice of expensive devices prefered. Recorder camera chips at most affordable with least storage spaces starts at $49 dependign on the type of cameras to suit. camera tripods stands usually would cost depending of the size either as domestic or outdoor setup costs in above couple hundred dollars. $149. Cameras that perform on backup power sources with several hours least requiring recharging are couple hundred dollars and above dependign on the extensive lastings capacity of battery supply at assigments. Consult with an electronic store retailers expert to ascertain the available sale prices. For example, the types of retail stores predict the prices avilable for each device at purchase. for example, products acquired from luxurous retailers requrie guarantee, warrantee acquisition also to make the experince acheievable. Usually more expensive camera devices have more expensive warantee costs at purchase. For example, buying a camera that cost $500 as base price after store taxes of 8% sums much differently. Warrantee may usually become couple hundred, where &149 dollars for basic warantee to several hundred dollars to full extensive years of warantees arragment with either the retails store or manufacturer.
Feb 06, 2011 | DXG Technology DXG-572V Digital Camera
How much does the 60,000 service cost?
The cost can range from 500 to 1000 dollars. It all depends on what has depreciated on the current vehicle. With that said; You should expect to pay around 800 dollars, at most, for the 60k service. You can request to not have certain check points covered to lower the end price, but I don't recommend that at all.
The tries will usually inflate the price past 1000 dollars if they need replacing during the service inspection.
Aug 25, 2010 | 2008 Infiniti FX35
THE HEAT IS OUT ON IT AND i TOOK IT TO BE FIXED. i PAID HIM 900 DOLLARS AND IT WAS NOT FIXED NOW HE SAYS HE NEEDS ABOUT 500 MORE DOLLARS TO REPLACE THE COIL...I FEEL LIKE IT IS A RIP OFF?
If the car runs the you don,t need a coil unless you ment "core",but i doubt that because for 900.dollars it should have been already replaced.Check your receipt and find out exactly what was done and let me know,i'm curious on this one.
Nov 04, 2009 | 2001 Mercury Sable
Visors in my beetle
go and check any beeyle spares and by joining so you will be sent email and or text if you want for eventual parts seconhand mostly
if you go to a dealer and ask the price when new you will know a one third of the price is for secondhand
go to auctions and ebay and to local scarp yards
to replace it it is very easy you cab do it but any mechanuc could ask you10-20 dollar pounds euros a sealer will charge you more
at a scrap dealer they will do so byt 5-10 pounds dollar euro if you ask them
Sep 27, 2009 | 1999 Volkswagen Beetle
My Lexmark printer is not working.
Lexmark is the lowest quality of printers. The printer has malfunctioned. I have seen Lexmark printers malfunction all of the time.
Try a color laser printer (HP is very good).
You probably want a all-in-one printer. However, the price of the scanner separate is about 50 dollars and the printer is about 140 dollars.
A laser printer can last around 7 years, whereas an inket only about 2-4 years. Ink in the life of an inkjet can cost around 500 dollars, half if you can refill it.
Aug 09, 2009 | Lexmark X2600 InkJet Printer
Uniden Bcd996xt Scanner Logo
43 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
