SanDisk Sansa View 8GB MP3 Player - Black Logo
Posted on Apr 26, 2009
Sansa player is frozen with the blue ring illuminated
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
487
Points
5
I had same problem a while back..
Solution is to Hold the on/off button in "turn off" position for about 50 seconds....
that's it....
5helpful
My sansa fuze at times freezes. I do not know why,
When the blue ring is illuminated, first try the RESET for the Sansa Fuze.
The player should NOT be connected to any other device:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
When a RESET won't work or the player freezes again, UPDATE the firmware on the player in 2 steps.
> step1: Enable MSC mode
1. Turn device OFF: when the player is frozen first perform step 1 and 2
of the RESET procedure:
seconds.
2. Slide the Hold switch down to Lock (orange colored dot showing).
3. Press and hold the left button ( |<< ) while connecting the device to the PC.
> step 2 : UPDATE the firmware
Use next page for updating the firmware on the player.
http://kb.sandisk.com/app/answers/detail/a_id/278
There are 2 methods for updating, for Windows operating system the
updater ( method 1 ) should work:
Method 1; Use the Sansa Firmware Updater
Method 2: Use the update board / Sansa forum
Look in the Update page for the steps to follow.
3helpful
My sansa view won't turn on, the blue ring illuminates but that is all it does
Alright it seems your sansa is on its way out. I had to essentially mash on the center keypad while holding the power button in the on position before it finally worked. Be prepared to buy a new one, mine only lasted for 2 weeks after it started doing that
1helpful
My sansa wont turn on, I took out battery to reset and blue ring
Try resetting your firmware via Sandisk's support site. If it still doesn't work, your sansa's mainboard might be busted. The cost of replacing it will be more than a refurbished one (under $40 online).
Black screen, lit up blue wheel ,won't turn off or on
Goto > http://www.sansa.com/support/sansa_view/faqs
There is a FAQ page here that might help you.
1helpful
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
Sansa e250
I have a proplem with my sansa e250 after upgrading it. Now I can't start my sansa. The whole sansa is frozen. Just appear SanDisk logo on the screen, blue wheel lite and that's all.
I tryed several time to reset it by pressing the power on (menu) buton for more than 15 sec. It power of after that, but when I try to start it again problem persist - sansa e250 is frozen after logo of sandisk apear on the screen.
Please help me
2answers
Sansa e 200
my sansa e200 is having some problems the ring is lite up but the screen is black i tryed alot of things nothing is really working can you please HELPPPPPP me pleaseeee
Sansa c200 frozen
Have you tried to reset the device by holding the power button?
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
