Question about Maytag Dryers
YNED7200TW0 Amana Electric dryer is reading T5 and not starting its dry cycle or any cycle, we did some research and looked at some of the parts that could have been the problem, the thermistor was the first guess because it looked like the wires were broken/melted, but after replacing it with a new one it was still reading T5. Is there suppose to be continuity in the thermistor or even the thermostat? and what exact wires need to be checked for resistance?
  • 159 Answers
SOURCE: Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Posted on Jul 13, 2007
skrbin
  • 121 Answers
SOURCE: Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Posted on Feb 15, 2009
protek480
  • 1714 Answers
SOURCE: whirlpool duet not heating, replaced thermistor
If it just won't heat, it's a thermostat issue (most likely). You can try a different setting and check if it works. There are different thermostats for different settings. Also there is a contact that is operated by the motor to insure that the drum is turning for heat.
Posted on Jul 02, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
milten1
  • 1304 Answers
SOURCE: GE Profile dryer - automatic dry never stops
ok go back to that page and
look in the
backsplash, blower section
you are looking for part
230
Posted on Oct 15, 2009
Testimonial: "Fast and Courteous Feedback!!! Thanks again!!"
T5 error code
test the thermostat and thermistor too and replace, if the problem persist, clean the ducts, or need to replace the control board if the problem . If the problem continue
make this test.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Oct 01, 2013 | Amana NED7200TW Electric Dryer
Amana electric dryer. NED7200TW t5 error. I pulled out the dryer, unplugged it (4prong thank you) made sure the flexible duct was clear and not kinked, checked the outside vent to make sure it was clear...
throw it out,older , less fancy dryers with fewer features last a lot longer,had one for 16 yrs,motor,belt ,rotor and drum wheels can be fixed by replacement,take hair dryer to key pad
Sep 01, 2013 | Amana NED7200TW Electric Dryer
NED7200tw t5 error Code
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
5. Power ON
Aug 08, 2012 | Amana NED7200TW Electric Dryer
I have model # MDE6700AYW (Maytag Neptune electric dryer) Error code T5, service codes 0, 19 and 76. Can anyone tell me what part needs to be replaced?
5. Power ON
Here is a link to the part in case you need it.
Aug 23, 2011 | Maytag Neptune MDE6700A Electric Dryer
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
T5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Amana NED7200TW Electric Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Amana gas dryer fine on regular settiing, poor on delicate
It would be unusual but this could be a bad timer in the control panel. The only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru --- www.RepairClinic.com
http://www.repairclinic.com/Amana-Dryer-Parts?z=100
Jan 26, 2009 | Amana ALG331RAW Gas Dryer
Dryers Logo
16 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
