Question about Electrical Supplies
I have a 1991 holiday Rambler free spirit feather lite 5th wheel and I need to locate the converter box.
4 Suggested Answers
SOURCE: where is my 1991 holiday rambler travel trailer converter
I had a similar problem on my 1995 Holliday Rambler Aluminalite 29 foot travel trailer with the similar layout of your trailer. My converter was only putting out 12.28 Volts DC. I fount the converter under the front of the trailer. (facing the front of the trailer, just right of center about 8" back)
There was a pannel with screws on the underbelly. I could hear the humm of the transformer. I removed the cover and found the red wire from the converter to a stud nut was loose. Tightened the nut and now I have 13.29 Volts DC.
Regards.
Posted on Aug 27, 2009
SOURCE: where is the converter box located in my 1989
Where is the power converter located in a 1989 holiday rambler
Posted on Sep 14, 2010
emissionwiz
  • 76846 Answers
SOURCE: where can i get a FREE owners manual for a 1989 holiday rambler aluma lite xl travel trailer imperial
We have no information on travel trailers. This forum is for car and truck information. I would suggest you contact a dealer of the trailer and ask how to order one.
Posted on May 06, 2016
What size trailer tires does a 1988 Holiday Rambler have on it?
Your Holiday Rambler most likely has an LT35/85-16, which is the most common for campers, 5th wheels and toy haulers. However, what you need to look for is the info plate on the unit, showing the VIN, tire size and pressure for each tire and the GVRW for your unit. Look for the Load Range. Depending on the axles and weight, you most likely have Load Range E. If you are looking for replacement tires, you may want to consider an ST235/85-16E. The ST has a hard composition rubber so the life and mileage is much longer, besides usually being less expensive.
Just to give you an example from my personal trailer, the Goodyear LT235/85-16 Load Range G average cost is @ $340.00/ tire but the replacement ST235/85-16 Load Range G cost$185.00 each. Great warranty, longer life and much cheaper. I am a Full Time RV'er traveling all over the country so mind gets a lot of mileage. It's worth the switch.
Apr 12, 2017 | Holiday Rambler RVs
I have a 2003 Holiday rambler presidential 5th wheel and my bedroom slide will go out but won't come in with the switch. I replaced the switch and the battery and it still doesn't work. Help please.
You need to get to the motor and see if there is power going to it in both directions. Does it sound like the motor is running but nothing moving?
Apr 03, 2017 | Holiday Rambler RVs
We have a 2001 presidential 5th wheel it is hooked up and plugged and everything works but the lights. Is there a separate switch to turn these on?
There is probably a breaker box in the bedroom closet behind a panel. Look elsewhere if not there and check the breakers when you find it. You may have a short circuit somewhere and the breaker opened. Or maybe even a failed breaker. Check for voltage at the breaker itself. Don't assume the breaker is getting power.
Feb 03, 2017 | Holiday Rambler 2010 Presidential 36RET
Replacing floor of a slide on a 5th wheel camper
decorative floorlyer, martin ...01413891269 he will fit for you top notch.
Sep 10, 2016 | Holiday Rambler 2008 Alumascape 32CKQ
Where can i get a FREE owners manual for a 1989 holiday rambler aluma lite xl travel trailer imperial
May 06, 2016 | Cars & Trucks
Where is the fel pump fuse located
1997 Holiday Rambler Endeavor LE ... The early F53 has a "fuse box" located under/in the dash somewhere near the steering column. ... fuel pump, ignition, headlamps
May 31, 2014 | RVs
Trying to find location of my OBD connector on a 1997 Holiday Rambler 37' motorhome. it has the Ford 460 engine.
if i did not forgot, for 1997 Holiday Rambler, the OBD connector is below the steering wheel.
or you can ask the 24 hrs live OBD technical support, they will like to help you, good luck
Aug 03, 2013 | 1988 Dodge D-Series Pickups
Where is the converter box located in my 1989 holiday rambler?
Mar 06, 2010 | Electronics - Others
Where is my 1991 holiday rambler travel trailer converter
Regards.
May 07, 2009 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
