Defy model dtl 120 automatic serial no.k472900153 washing machine drain pump not switching of pump run continuesly
2 Suggested Answers
SOURCE: error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Posted on Jul 28, 2008
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
Defy DAW370
time to replace timer/electronic control board and fix it.
You can get part from www.repairclinic.com
God bless you
Jul 11, 2013 | Motorola Mobility Defy Cell Phone
It fills up..washes..but wont drain or spin out..
I had the same problem. Checked the pump and it ran fine. Took off the door locking mechanism and put 120 ohms into the wax motor part and it tested fine too. I read about problems with that wax motor so I replaced the complete door switch today for $71.00 and the washer runs perfectly now. If it won't spin or even fully drain I suggest replacing the door switch.
Jul 14, 2009 | Washing Machines
Washing machine will not finish cycle and the reduced creases and the mini load buttons continuesly flash. Do you know how to solve this problem? My problem is same as earlier person identified sep 08. I...
Could be pressure switch jammed on empty, check pump for draining properly..
Select drain only and see if the water comes at a good rate, there are other problems that could the sequence of lights flashing that you are experiencing.
Dec 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
